Author Topic: how to detect menu ?  (Read 5890 times)
Andrea
« on: September 23, 2005, 01:34:11 PM »
a little simple question...
maybe i already know....but I can find a way.....
I would like to detect if a menu is loaded or not...
and display a toolbar..
any idea ?
Keep smile...
M-dub
Re: how to detect menu ?
« Reply #1 on: September 23, 2005, 01:37:56 PM »
menuload?
Simple enough...
Andrea
« Reply #2 on: September 23, 2005, 01:45:44 PM »
sorry....i mean...in lisp..
eg:
(setq menulist ([list menu]))
or
(if ([Menu "X"]) (vl-cmdf "_-toolbar" "_s" "tb1"))
something like that.
Keep smile...
M-dub
« Reply #3 on: September 23, 2005, 01:47:15 PM »
Lisp, eh?  I think you should have posted this in the Lisp forum.  I'll move it.
Andrea
« Reply #4 on: September 23, 2005, 02:02:21 PM »
ok....sorry, :?
Keep smile...
Crank
« Reply #5 on: September 23, 2005, 02:12:46 PM »
RTFM  :evil: :
VLISP-help > Menus property, example code
Sub Example_Menus()
    ' This example finds the names of all menus in the first menu group.
    Dim menuNames As String
    Dim menuCollection As AcadPopupMenus
    Dim menu As AcadPopupMenu
    Set menuCollection = ThisDrawing.Application.MenuGroups.Item(0).Menus
    menuNames = ""
    For Each menu In menuCollection
        menuNames = menuNames & menu.name & vbCrLf
    Next menu
    MsgBox menuNames
End Sub
Andrea
« Reply #6 on: September 23, 2005, 02:18:35 PM »
Thanks Crank...
but I found a easier way..
(menugroup groupname)
Keep smile...
Crank
« Reply #7 on: September 23, 2005, 02:28:35 PM »
Perhaps you can use this function from acadx.com :
(defun ax:ListToolbars (groupName / mGroups mGroup lst)
  (if (not
(vl-catch-all-error-p
  (setq
    mGroup (vl-catch-all-apply
     'vla-item
     (list (vla-get-menugroups (vlax-get-acad-object))
   groupName
    (vlax-for tBar (vla-get-toolbars mGroup)
      (setq lst (cons (vla-get-name tBar) lst))
Crank
« Reply #8 on: September 23, 2005, 02:35:14 PM »
(to check if the toolbar still exists)
Andrea
« Reply #9 on: September 23, 2005, 02:46:29 PM »
humm... :?
interresting.. thanks.
But how it work ?..
I can found a way to run the routine..
« Last Edit: September 23, 2005, 02:50:36 PM by Andrea »
Keep smile...
Dommy2Hotty
« Reply #10 on: September 23, 2005, 03:00:13 PM »
Just for reference:
(if (menugroup "ase_partial")
(alert "ASE Partial Menu is loaded.")
(alert "Cannot find specified menu.")
Andrea
« Reply #11 on: September 23, 2005, 04:23:56 PM »
Just for reference:
I mean...Crank's routine..
Keep smile...
Dommy2Hotty
« Reply #12 on: September 23, 2005, 04:28:35 PM »
Just for reference:
I know...just putting some other code out there for people to mull over...  :evil:
Crank
« Reply #13 on: September 23, 2005, 05:27:57 PM »
The routine only returns a list of all toolbars in a menu.
If you want to check if the toolbar exists you'll have to do something like:
(if (member "toolbarname" (ax:listtoolbars "menuname"))
   (princ "\nToolbar exists")
   (princ "\nToolbar not present")
The menuname and toolbarname are not allways the same as displayed on screen in autocad. You must use the names given in the .mnu/.mns or .cui
« Last Edit: September 23, 2005, 05:32:22 PM by Crank »
Jürg Menzi
  • Oberegg, Switzerland
« Reply #14 on: September 24, 2005, 06:33:38 AM »
For more functions around menus, visit my homepage -> 'Free Stuff' and search for:
VxGetLoadedMenus, VxUnLoadMenuGroup, VxGetPopups and VxGetToolbars
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
