Author Topic: wblock out of closed dwg  (Read 11359 times)
Amsterdammed
« on: September 21, 2005, 04:32:11 AM »
Hello Experts,
What I need to do is to get a wblock into an open drawing; the problem is that the wblock isn’t made yet. So what I wonder is if there is a way to select a dwg with the getfiled function and then get a selection set in that drawing with a  preset filter. But I don’t want to open the dwg visible where the wblock must come from. Is there any activex miracle that t does the trick? Or can I run a hidden 2nd Acad session doing the wblock work there?
Thanks in Advance
Bernd
Re: wblock out of closed dwg
« Reply #1 on: September 21, 2005, 05:06:19 AM »
To the best of my knowledge, not as you describe it. Selections <as such> are not possible with DBX. You could however import a block record from the unopened drawing.
« Reply #2 on: September 21, 2005, 08:37:00 AM »
Try the design center ... you can open it with ADCENTER and then browse to the DWG you want to grab something from, then select "blocks" then select the block you want .... pretty easy ...
Amsterdammed
« Reply #3 on: September 21, 2005, 09:07:47 AM »
Keith,
It is for you and me. But I need to get this into an application done for my co workers here, so the ss should show up on a certain moment in the lisp.
Bernd
« Reply #4 on: September 21, 2005, 01:35:47 PM »
Ok .. this works ... but it does not have alot of error checking.
;;;   IFF.LSP
;;;   Copyright ©2005 by K.E. Blackie
;;;   http://www.resourcecad.com
;;;   kblackie@resourcecad.com
;;;   AutoCAD 2000+  VisualLISP / ObjectDBX
;;;   Permission to use, copy, modify, and distribute this software
;;;   for any purpose and without fee is hereby granted, provided
;;;   that the above copyright notice appears in all copies and that
;;;   both that copyright notice and this permission notice appear in
;;;   all supporting documentation.
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;;;   WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;;;   PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;;   DESCRIPTION
;;;   C:IFF
;;; This program uses ObjectDBX in VisualLISP to import a block defined in any
;;; closed drawing file.
;;; There is limited error checking. It is presumed the user will modify this
;;; code to some degree to obtain the desired results.
;;; main function
(defun C:IFF (/ *acad*   block_list       block
      blocks dbxDwg   dcl_id    done      Dwgfn
      ins_block
  ;; load the com object
  ;; get the AutoCAD reference
  (setq *acad* (vlax-get-acad-object))
  ;; save our dialog file (saves us from having more than one file to deploy)
  (write_dialog)
  ;; get a drawing name
  (setq Dwgfn (getfiled "Open File" "*.DWG" "DWG" 8))
  ;; initialize our insert block to the first element in the list
  ;; just in case the user does not click on the drop down control
  (setq ins_block "0")
  ;; determine what version of AutoCAD we are running then open the appropriate
  ;; ObjectDBX interface version
  ;; We will register the ObjectDBX interface JUST IN CASE it already is not
  ;; Thanks goes to Kerry Brown at www.TheSwamp.org for putting the idea in my head
  (if (= (atoi (getvar "AcadVer")) 16)
      (setq DBXserver (findfile "AxDb16.dll"))
      (startapp "regsvr32.exe" (strcat "/s \"" DBXserver "\""))
      (setq dbxDwg
   (vla-GetInterfaceObject *acad* "ObjectDBX.AxDbDocument.16")
      (setq DBXserver (findfile "AxDb15.dll"))
      (setq dbxDwg
   (vla-GetInterfaceObject *acad* "ObjectDBX.AxDbDocument")
  ;; open the drawing
  (vla-open dbxDwg Dwgfn)
  ;; grab the blocks collection
  (setq blocks (vla-get-blocks dbxDwg))
  ;; for each block in the drawing .. grab it's name and make it into a list
  ;; filter for anonymous blocks, modelspace, paperspace and dimensions
  (vlax-for block blocks
    (if (/= "*" (substr (vlax-get-property block 'Name) 1 1))
      (setq block_list
     (append block_list
     (list (vlax-get-property block 'Name))
  ;; load our dialog definition
  (setq dcl_id (load_dialog "iff"))
  ;; our new dialog
  (new_dialog "bl_filter" dcl_id)
  ;; start our list of blocks
  (start_list "bl_names")
  ;; add them to the control
  (mapcar 'add_list block_list)
  ;; end the list
  (end_list)
  ;; define actions for our DCL controls
  (action_tile "bl_names" "(setq ins_block $value)")
  (action_tile "accept" "(done_dialog 1)")
  ;; start our dialog
  (setq done (start_dialog))
  ;; if we closed the dialog with the insert button
  (if (= done 1)
      ;; copy the block from the drawing header in the closed drawing
      (vla-CopyObjects
dbxDwg
(vlax-safearray-fill
  (vlax-make-safearray
    vlax-vbObject
    '(0 . 0)
  (list
    (vla-item
      (nth (atoi ins_block) block_list)
;; and put it in the current drawing
(vla-get-blocks
  (vla-get-ActiveDocument *acad*)
  ;; release our ObjectDBX drawing
  (vlax-release-object dbxDwg)
  ;; if we closed with the Insert button, then insert it
  (if (= done 1)
    (command "insert" (nth (atoi ins_block) block_list))
;;; dialog definition
(defun write_dialog (/ fn)
  (if (setq fn (open "iff.dcl" "w"))
      (write-line "bl_filter : dialog {" fn)
      (write-line "       aspect_ratio = 0;" fn)
      (write-line "       label        = \"Block Insert Tool\";" fn)
      (write-line "     : popup_list {" fn)
      (write-line "       key               = \"bl_names\";" fn)
      (write-line "     }" fn)
      (write-line "     : row {" fn)
      (write-line "     spacer;" fn)
      (write-line "     : ok_button {" fn)
      (write-line "       label       = \"Insert\";" fn)
      (write-line "       width       = 12;" fn)
      (write-line "       fixed_width = true;" fn)
      (write-line "       alignment   = right;" fn)
      (write-line "     : cancel_button {" fn)
      (write-line "       alignment   = left;" fn)
  (close fn)
Forgot to mention, this uses a technique employed by Tony Tanzilla to copy the block from one drawing to another.
« Last Edit: September 22, 2005, 09:15:20 AM by Keith »
« Reply #5 on: September 21, 2005, 05:22:43 PM »
As I posted, blocks are simple ..
Didn't Amsterdammed's original post and his reply #3 ask for a selection set .. which can't be done with DBX.
Chuck Gabriel
« Reply #6 on: September 21, 2005, 05:38:06 PM »
He couldn't do a selection set, but he could iterate over the database applying his filter criteria and use CopyObjects to get the accumulated objects into his active drawing.
« Reply #7 on: September 21, 2005, 05:38:59 PM »
Sure could.
« Reply #8 on: September 21, 2005, 05:47:14 PM »
Yep, certainly ..
:whistle:
Chuck Gabriel
« Reply #9 on: September 21, 2005, 06:35:04 PM »
Hmm.  I'm much more proficient in VB(A) then visual lisp so I'll post this VBA example and leave up to others to translate it into vlisp.  It is a little oversimplified, but it should get you going in the right direction.
Option Explicit
Const ERR_SUBSCRIPT_OUT_OF_RANGE = 9
Sub test()
  On Error GoTo ERROR_HANDLER
  ' Uses CommonDialog.cls from www.acadx.com
  Dim fileDialog As CommonDialog
  Dim fileName As String
  Set fileDialog = New CommonDialog
  With fileDialog
    .DialogTitle = "Select files:"
    .Filter = "Drawing files (*.dwg)|*.dwg"
    .DefaultExt = "dwg"
    .Flags = OFN_EXPLORER Or OFN_HIDEREADONLY
    .InitDir = ThisDrawing.Path
    If .ShowOpen Then
      fileName = .fileName
    Else
      Exit Sub
    End If
  End With
  Set fileDialog = Nothing
  Dim doc As AxDbDocument
  Dim ent As AcadEntity
  Dim index As Long
  Dim entities() As AcadEntity
  Set doc = New AxDbDocument
  doc.Open fileName
  index = 0
  For Each ent In doc.ModelSpace
    If TypeOf ent Is AcadText Then
      ReDim Preserve entities(0 To index) As AcadEntity
      Set entities(index) = ent
      index = index + 1
    End If
  Next ent
  Set ent = Nothing
  ' We will get a runtime error here if the array has not been redimmed
  ' That should be our cue to exit if it occurs
  Dim upper As Long
  upper = UBound(entities)
  Dim pairs As Variant
  doc.CopyObjects entities, ThisDrawing.ModelSpace, pairs
  Exit Sub
ERROR_HANDLER:
  Select Case Err
    Case ERR_SUBSCRIPT_OUT_OF_RANGE
      ' The entity array is empty
      Exit Sub
    Case Else
      Err.Raise Err.Number, Err.Source, Err.Description, Err.HelpFile, Err.HelpContext
  End Select
Amsterdammed
« Reply #10 on: September 22, 2005, 04:57:37 AM »
Keith,
if i run the IFF function i get tHis error msg
Automation Error. Problem in loading application
on this line of code
(setq dbxDwg
« Reply #11 on: September 22, 2005, 05:40:23 AM »
Which Version Of AutoCAD ?
What does This return ?
(substr (getvar "ACADVER") 1 5)
Amsterdammed
« Reply #12 on: September 22, 2005, 07:32:03 AM »
Sorry Kerry,
I bit stupid from me not to post earlier:  "15.06"
Bernd
« Reply #13 on: September 22, 2005, 07:41:38 AM »
Try this then :
           ((vl-registry-read "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID"
           ((not (setq DBXserver (findfile "AxDb15.dll")))
            (alert "Error: Can't locate ObjectDBX Library (AxDb15.dll)")
           (t
            (or
              (vl-registry-read
              (alert
                "Error: Failed to register ObjectDBX ActiveX services for AutoCAD2002."
Amsterdammed
« Reply #14 on: September 22, 2005, 08:00:27 AM »
