Author Topic: wblock out of closed dwg  (Read 11346 times)
Re: wblock out of closed dwg
« Reply #30 on: September 22, 2005, 10:59:49 AM »
Indeed .. that is why ... you should request your IT staff enable this ..
Amsterdammed
« Reply #31 on: September 23, 2005, 02:48:06 AM »
Keith,
I wish that was that easy. The are as flexible as concrete. Is there a way that i can open a 2nd acad session with visible = false and do simply with lisp the wblock work?
Bernd
« Reply #32 on: September 23, 2005, 02:50:49 AM »
I am speechless.
Amsterdammed
« Reply #33 on: September 23, 2005, 03:04:56 AM »
What do you mean Kerry?
« Reply #34 on: September 23, 2005, 03:13:42 AM »
... if I understand you correctly ..
I find it incomprehensible that your IT people would not assist. DBX used properly is significantly productive.
 ..essentially, they are stopping you from doing your job.
added. : Can you talk to your Manager about this ? .. 'cause it's too important to ignore.
« Last Edit: September 23, 2005, 03:16:54 AM by Kerry Brown »
Amsterdammed
« Reply #35 on: September 23, 2005, 03:51:05 AM »
Kerry,
You have no Idea how right you are. But although I’m working for a Dutch Company (thank God that I’m not Dutch), I’m tired of fighting Wind mills.
The good thing is that they reorganise the whole circus here and fire 800 of the 9000 people, and I pray that there will be my IT enemies among them.
And than I will give it a new try.
Bernd
 :evil:
« Reply #36 on: September 23, 2005, 08:44:37 AM »
It might be able to be done by opening another AutoCAD session that is hidden ... only sometimes AutoCAD willl recognize that another session is running and then terminate the new application and open the drawing in the current session. The only way I would be able to tell you to verify this would be to actually try it.
Can you open AutoCAD 2 times on your computer? If so, then you should be able to do it, but the solution would be in VBA unless you could import the various type libraries into VLisp.
Amsterdammed
« Reply #37 on: September 23, 2005, 09:54:16 AM »
Keith,
yes, i can open Acad more than one toime on my PC. VBA should be ok, too.
Thanks,
Bernd
