Author Topic: wblock out of closed dwg  (Read 11351 times)
Chuck Gabriel
Re: wblock out of closed dwg
« Reply #15 on: September 22, 2005, 08:06:25 AM »
Doh!  Now I see.  Sorry Keith.
« Reply #16 on: September 22, 2005, 08:11:30 AM »
What is returned from :-
This ;
(setq DBXserver (findfile "AxDb15.dll"))
Then this ;
(startapp "regsvr32.exe" (strcat "/s \"" DBXserver "\""))
« Reply #17 on: September 22, 2005, 08:23:59 AM »
Try this:
Browsing to your AutoCAD directory
Find AxDb15.dll
Right click on AxDb15.dll
OpenWith -> Browse to regsvr32.exe
If the result is successful, then the proggie will work
Amsterdammed
« Reply #18 on: September 22, 2005, 09:01:47 AM »
Kerry,
33
"C:\\Program Files\\AutoCAD 2002\\AxDb15.dll"
« Reply #19 on: September 22, 2005, 09:05:55 AM »
Should work now, did you try?
« Reply #20 on: September 22, 2005, 09:06:25 AM »
Well you should work then ...
Amsterdammed
« Reply #21 on: September 22, 2005, 09:14:57 AM »
Same error
« Reply #22 on: September 22, 2005, 09:16:53 AM »
This error?
Automation Error. Problem in loading application
« Reply #23 on: September 22, 2005, 09:18:31 AM »
Hmmm ... Replace --
ObjectDBX.AxDbDocument
with
ObjectDBX.AxDbDocument.15
/guess
« Reply #24 on: September 22, 2005, 09:24:38 AM »
Hmmm ... Replace --
with
/guess
Nope .. the ObjectDBX application class name is either:
ObjectDBX.AxDbDocument (versionless)
ObjectDBX.AxDbDocument.1 (R15 2000-2002)
ObjectDBX.AxDbDocument.16 (R16 2004-2006)
Amsterdammed
« Reply #25 on: September 22, 2005, 09:25:05 AM »
No Michael
same error,
error: Automation Error. Problem in loading application
« Reply #26 on: September 22, 2005, 09:33:16 AM »
Ok .. what does this return?
(vl-registry-read "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID" )
Amsterdammed
« Reply #27 on: September 22, 2005, 09:36:15 AM »
nil
« Reply #28 on: September 22, 2005, 09:52:01 AM »
That means that for some reason ObjectDBX is not registered ...
Try browsing to the file like I said in this post
Amsterdammed
« Reply #29 on: September 22, 2005, 10:47:48 AM »
Keith,
It fails.
It gives a code 0x800200009
I’m afraid it won’t work here in this environment.
The reason might be in the system here, we are locked on to a remote server, have no writing rights on c. The reason is that we van get to every PC in every office and will log on to our stuff.
Sorry for wasting you time
Bernd
