Author Topic: Weld Symbols  (Read 12462 times)
deegeecees
Re: Weld Symbols
« Reply #15 on: January 30, 2006, 02:00:56 PM »
Try and test this, work fine here.
François
Rename 1735c.txt for 1735c.slb
I like that one much better, thanks Francois!
meco3hp
Re: Weld Symbols
« Reply #16 on: February 27, 2008, 11:10:14 AM »
Hello,
      I found this thread in a search for "weld symbols".
I downloaded it and got it to load, but like most that posted to this thread, the slide library didn't have anything in it. CAB had a change to the acad.mnu, but I did a search for the acad.mnu and can't find it. Any help? I'm using acad 2006 vanilla.
Thanks!
Richard
Re: Weld Symbols
« Reply #17 on: February 27, 2008, 11:47:32 AM »
Copy these files and try this other routine.
http://www.theswamp.org/index.php?topic=6909.msg109181#msg109181
meco3hp
Re: Weld Symbols
« Reply #18 on: February 27, 2008, 11:58:16 AM »
Hello,
       I tried that and got the following error;
ERROR! FILE NOT FOUND: WELD.DCL
Thanks!
Richard
Re: Weld Symbols
« Reply #19 on: February 27, 2008, 12:34:47 PM »
That file must be placed in the ACAD search path.
PS,  rename the dcl file to "WELD.DCL"
« Last Edit: February 27, 2008, 12:38:05 PM by CAB »
Theo
Re: Weld Symbols
« Reply #20 on: August 29, 2014, 08:24:14 PM »
Mr. Cab,
I cannot get access to a slide and icon library. Please provide me with those files, so I can try to run the AWELD.LSP
Thank you,
Theodorus Winata
twinata@shaw.ca
andy_lee
Re: Weld Symbols
« Reply #21 on: August 29, 2014, 10:53:21 PM »
where is the WELDS.SLB ?
andy.
Best regards.
Re: Weld Symbols
« Reply #22 on: August 29, 2014, 11:06:35 PM »
As CAB has indicated,
rename Tip1735b.dcl to WELD.DCL
also,
rename Tip1735c.txt to WELD.SLB
« Last Edit: August 29, 2014, 11:09:45 PM by Kerry »
andy_lee
Re: Weld Symbols
« Reply #23 on: August 30, 2014, 03:12:40 AM »
also,
Thanks kerry.
;                    AWELD  Ver. 3.1
;          Welding Synbol Placement Procedure
;         By Eric Howard [76424,1036] 11-18-92
I mean this  lisp lack of SLB files .
andy.
Best regards.
Re: Weld Symbols
« Reply #24 on: August 30, 2014, 04:28:53 AM »
I have no idea :|
Perhaps someone who was involved with the thread will be able to assist you.
Re: Weld Symbols
« Reply #25 on: August 30, 2014, 11:00:44 AM »
Wow this is an old one.
andy_lee
Re: Weld Symbols
« Reply #26 on: August 31, 2014, 10:58:06 PM »
Thank you CAB, and Thanks Kerry.
andy.
Best regards.
Theo
Re: Weld Symbols
« Reply #27 on: September 02, 2014, 03:05:16 PM »
About Aweld.lsp
Missing slb file and the routine does'nt work.
Regards,
Theo
Re: Weld Symbols
« Reply #28 on: September 02, 2014, 03:39:57 PM »
Did you try version 4? The slide are in the zip file. I have not run the routine.
