Author Topic: Question 30 goes here  (Read 36597 times)
Re: Question 30 goes here
« Reply #15 on: September 16, 2005, 01:58:51 PM »
<cough> Hyperlink.
« Reply #16 on: September 16, 2005, 02:00:11 PM »
Looked at the documentation a little closer and found this http://www.theswamp.org/screens/ronjonp/clue.htm
LE
« Reply #17 on: September 16, 2005, 02:01:48 PM »
If you don't want to post it yet that's fine but if I am close please PM me.  If I am way off base then don't worry about it.
Way off..... sorry
whdjr
« Reply #18 on: September 16, 2005, 02:01:57 PM »
:lmao:
not
 :pissed:
LE
« Reply #19 on: September 16, 2005, 02:03:01 PM »
« Reply #20 on: September 16, 2005, 02:03:58 PM »
LE
« Reply #21 on: September 16, 2005, 03:26:13 PM »
Ok,
Here is a vlx file to test this, after that I will post the open source.
Please place the vlx in the same folder with your drawing and load it.
1. Call the command TST
2. Save the drawing and open it again
3. What happen?
4. Is the TST command available?
5. Look on the APPLOAD list and see if the SELFLOAD.VLX is there?
Sdoman
« Reply #22 on: September 16, 2005, 03:27:14 PM »
Does the soution have to do with editing the AutoCAD registry?  I thought I read something about that somewhere...Don't know where.
LE
« Reply #23 on: September 16, 2005, 03:34:19 PM »
Please do the test on a new drawing... or make a backup first.....
« Reply #24 on: September 16, 2005, 03:40:35 PM »
<cough>
(&VLO-C lisplet-permanent-data-handle "selfload")
« Reply #25 on: September 16, 2005, 05:30:32 PM »
Argggg ... I'm this close to crackin' this nut.
 :evil:
LE
« Reply #26 on: September 16, 2005, 05:39:22 PM »
 :evil:
What do you think Michael, is this worth or not..... ? or is a mickey-mouse....
« Reply #27 on: September 16, 2005, 05:43:04 PM »
It's fun crackin' it.
VLO-VL objects, lol, who knew.
Weirdness: '(0   . "VLO-VL") yet '(100 . "vlo_VL") ...
LE
« Reply #28 on: September 16, 2005, 05:47:36 PM »
It is time to post the code?....
« Reply #29 on: September 16, 2005, 05:47:43 PM »
PLEASE DON'T POST ANY CODE YET LUIS.
