Author Topic: multiple xrefs....  (Read 7626 times)
multiple xrefs....
« on: September 15, 2005, 06:43:35 PM »
Do any of you have a routine to force an xref to be detached even if it exist more than once in a drawing on multiple tabs?
Thanks,
Ron
Re: multiple xrefs....
« Reply #1 on: September 15, 2005, 06:48:17 PM »
If you erase all instances of an xref, save the drawing, and then re-open it AutoCAD will dump the xref definition all by itself. Of course, one can automate this via lisp /vba too ...
« Reply #2 on: September 15, 2005, 06:56:33 PM »
Michael,
I've been deleting all instances manually and got tired of it.....so you know anyone that could whip up this routine :wink:.
Ron
« Reply #3 on: September 15, 2005, 07:06:49 PM »
Michael,
Ron
Ahhh. Sorry bud, I'm tied up until 10pm +/- and the little bit of grey matter I'll have left after that won't be of much use (not that I'm currently all that coherent). But fear not, lot's of capable hands here ...
Bob Wahr
« Reply #4 on: September 15, 2005, 07:31:21 PM »
no error control, limited thought, less testing but this should get you.
Sub KillDaXwefs()
Dim objWascawyXwef As AcadBlock
Dim objblks As AcadBlocks
Dim intCnt As Integer
Set objblks = ThisDrawing.Blocks
For intCnt = objblks.Count - 1 To 0 Step -1
  Set objblk = objblks(intCnt)
  If objblk.IsXRef Then
    objblk.Detach
  End If
Next intCnt
End Sub
Andrea
« Reply #5 on: September 15, 2005, 08:27:22 PM »
simply use....
OVERKILL  command.
 :lol:
Keep smile...
« Reply #6 on: September 15, 2005, 11:52:32 PM »
Assuming all instances share the same insert point and scale would be folly imo.
« Reply #7 on: September 15, 2005, 11:53:44 PM »
Isn't that what backups are for ??
« Reply #8 on: September 15, 2005, 11:57:42 PM »
<Jeff Spicolli> Whaaaa? </Jeff Spicolli>
« Reply #9 on: September 16, 2005, 12:03:42 AM »
« Reply #10 on: September 16, 2005, 12:27:53 AM »
lol, touche.
 :-D
« Reply #11 on: September 16, 2005, 10:05:58 AM »
simply use....
OVERKILL  command.
No workie...
Bob,
I get an error with your code "Duplicate Key" on the line     objblk.Detach
Ron
Bob Wahr
« Reply #12 on: September 16, 2005, 11:04:58 AM »
Sub KillDaXwefs()
Dim objSelSet As AcadSelectionSet
Dim objSelSets As AcadSelectionSets
Dim intGroup(0) As Integer
Dim varData(0) As Variant
Dim strSetName As String
Dim objBlkRef As AcadBlockReference
Set objSelSets = ThisDrawing.SelectionSets
strSetName = "LeftInAlbekoikie"
  intGroup(0) = 0: varData(0) = "INSERT"
  KillSet strSetName
  Set objSelSet = objSelSets.Add(strSetName)
  objSelSet.Select acSelectionSetAll, , , intGroup, varData
  For Each objBlkRef In objSelSet
    If TypeOf objBlkRef Is AcadExternalReference Then
      objBlkRef.Delete
    End If
  Next objBlkRef
  Set objWascawyXwef = objblks(intCnt)
  If objWascawyXwef.IsXRef Then
    objWascawyXwef.Detach
  End If
Next intCnt
End Sub
give this one a shot then
« Reply #13 on: September 16, 2005, 11:19:04 AM »
Now it says sub or function not defined:  KILLSET
hhmmm
Ron
Bob Wahr
« Reply #14 on: September 16, 2005, 11:20:22 AM »
sorry.  Toss this in with it
Function KillSet(strSet As String)
  For Each objSelSet In objSelSets
    If objSelSet.Name = strSet Then
      ThisDrawing.SelectionSets.Item(strSet).Delete
    Exit For
    End If
  Next
End Function
