Author Topic: Meeses To Peeses  (Read 5527 times)
deegeecees
Meeses To Peeses
« on: September 15, 2005, 04:38:20 PM »
I know this is probably a system issue, and I've searched the forums, but you people seem to have the answers that I can't find. My mouse only pans left and right. This is very cumbersome, I mean, come on I remember when pan wasn't even a transparent command, but I thought those days were over. I tried MBUTTONPAN = 1 and 0, to no avail, I tried CP Mouse settings, I'm stumped.
Re: Meeses To Peeses
« Reply #1 on: September 15, 2005, 04:40:54 PM »
Mouse hygiene me thinks. Is it an optical or mechanical? If the latter, open it up and remove the crud that has collected around the vertical spindle.
/guess
Bob Wahr
« Reply #2 on: September 15, 2005, 04:42:07 PM »
is it only on pan or is it just in general?  Try a -pan.
deegeecees
« Reply #3 on: September 15, 2005, 04:42:23 PM »
Its optical.
« Reply #4 on: September 15, 2005, 04:43:24 PM »
Visine?
deegeecees
« Reply #5 on: September 15, 2005, 04:44:45 PM »
When I hold the wheel down, I get the "circle w/arrows" style panning where if I leave it go, it will pan forever in the direction I started, and its only left to right in AutoCAD.
deegeecees
« Reply #6 on: September 15, 2005, 04:45:41 PM »
Visine?
I don't need to get the red out I need to pan properly.
deegeecees
« Reply #7 on: September 15, 2005, 04:47:54 PM »
I'm thinking its in my mnu file. Anybody know where the middle mouse button setup is in the acad.mnu?
deegeecees
« Reply #8 on: September 15, 2005, 04:48:44 PM »
Hey, look, I'm posting reeeel fast
deegeecees
« Reply #9 on: September 15, 2005, 04:49:16 PM »
ZOOOOOOOooooooooooooom
deegeecees
« Reply #10 on: September 15, 2005, 04:50:05 PM »
This'll get my post #'s up
David Hall
  • Automatic Duh Generator
« Reply #11 on: September 15, 2005, 05:01:25 PM »
i think its a system setting in windows
V-Man
« Reply #12 on: September 15, 2005, 05:32:04 PM »
I believe it's a setting in you Control Panel/Mouse and then under the Scrolling tab there is a setting in there that is causing the problem. Try unchecking the Enable Accelerator option.
« Reply #14 on: September 15, 2005, 10:42:01 PM »
This is the default if you hold the control key when pressing the middle button ...you may have inadvertently changed the setting in windows or the accellerator options.
