Author Topic: Hmm  (Read 6430 times)
rude dog
Hmm
« on: September 14, 2005, 07:30:30 PM »
When the hide command is initiated (on a 3d model) how does that little cursor spin 360 degrees (@ the command prompt) until the model is "hidden".....Can we right code to mimic that same thing? :|
Bob Wahr
Re: Hmm
« Reply #1 on: September 14, 2005, 07:48:57 PM »
Not sure if it can be done in lisp.
Where in AZ are you?
Re: Hmm
« Reply #2 on: September 14, 2005, 08:18:03 PM »
If I'm not mistaken what you're seeing is coded in lisp. I don't have any code right now but I'm sure one of the big guns will be along in a few to provide. You use a cond statement to repeat the strings "\"  "|"  "/"  "-" so it looks like it's spinning.
Bob Wahr
Re: Hmm
« Reply #3 on: September 14, 2005, 08:35:00 PM »
Doh!  missed the at command prompt.  I was thinking mouse cursor.  I think I have something somewhere that does this.  Am looking.
Bob Wahr
Re: Hmm
« Reply #4 on: September 14, 2005, 08:39:50 PM »
Found this
(defun c:spin (wh)
(prompt (strcat "\r "
wh
(cond ((= sp "|") (setq sp "/"))
((= sp "/") (setq sp "-"))
((= sp "-") (setq sp "\\"))
(T (setq sp "|"))
here
Re: Hmm
« Reply #5 on: September 14, 2005, 08:50:55 PM »
There it is!! Way to go Bob.  :kewl:
rude dog
Re: Hmm
« Reply #6 on: September 14, 2005, 08:59:17 PM »
Jeez that was quick..........
Thank you Mark and Bob
Location mostly <Mesa>
P.S
The forum looks fantastic
SPDCad
Re: Hmm
« Reply #7 on: September 15, 2005, 10:57:30 AM »
(defun c:spin (wh)
wh
(T (setq sp "|"))
Damn, someone beat me to it agian! :(
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
Re: Hmm
« Reply #8 on: September 15, 2005, 11:54:46 AM »
Another variant:
(defun busy ( )
    (princ
        (strcat "\r"
                (setq *busy* ;; oh my, a global
                    (cdr
                        (assoc *busy*
                *busy*
                (setq *busy* "\\")
Test drive:
(defun nop ( )
    (repeat 50000
(repeat 100
    (nop)
    (busy)
Andrea
Re: Hmm
« Reply #9 on: September 15, 2005, 08:40:54 PM »
Bob...
I got an error when tryin your routine...
Command: spin
; error: too few arguments
Keep smile...
Re: Hmm
« Reply #10 on: September 15, 2005, 08:55:38 PM »
(c:spin "The world is coming to an END")
Andrea
Re: Hmm
« Reply #11 on: September 16, 2005, 08:44:04 AM »
 :? oops....
Keep smile...
Re: Hmm
« Reply #12 on: September 17, 2005, 08:25:33 AM »
Had this in my library, Don't know the author
(defun SPIN ()
  (setq a_s (if a_s a_s 4))
  (princ
    (strcat
      "\r"
      (cadr
        (member
          (rem (setq a_s (1+ a_s)) 4)
          '(0 "|" 1 "/" 2 "-"3 "\\")
Edit: Looking a little closer the a_s is a runaway variable!
« Last Edit: September 17, 2005, 08:42:40 AM by CAB »
Re: Hmm
« Reply #13 on: September 17, 2005, 08:51:17 AM »
I tried to come up with one of my own.
(defun SPIN ()
  (or *spin* (setq *spin* 4))
  (princ
    (strcat
      "\r"
      (substr "|\\-/"
        (setq *spin*
               (if (zerop (1- *spin*))
                 4 (1- *spin*)))
      1)
Re: Hmm
« Reply #14 on: September 17, 2005, 09:16:53 AM »
How about something different?
(defun SPIN ()
  (or *spin* (setq *spin* (list '1+ 1)))
  (princ
    (strcat "\r"
            (substr "**********" 1 (cadr *spin*))
            (substr "           " (1+ (cadr *spin*)))
    ((= (cadr *spin*) 0)
     (setq *spin* (list '1+ 2))
    ((= (cadr *spin*) 10)
     (setq *spin* (list '1- 9))
    (t
     (setq *spin*
            (list (car *spin*)
                  (apply (car *spin*) (cdr *spin*))
