Author Topic: Visibility = false  (Read 2387 times)
Visibility = false
« on: September 14, 2005, 01:02:18 PM »
How would one go about showing all objects in a drawing who's visibilty is set to false via lisp?
Thanks,
Ron
Re: Visibility = false
« Reply #1 on: September 14, 2005, 01:07:03 PM »
Define show, do you mean temporarilly display or to force visibility on?
« Reply #2 on: September 14, 2005, 01:10:17 PM »
Sorry,
Force to visibility on.
« Reply #3 on: September 14, 2005, 01:26:36 PM »
This works:
(defun c:so (/ s1 index ent obj)
 (command ".undo" "begin")
  (if (setq sl (ssget "x"))
      (setq index -1)
      (while (< (setq index (1+ index)) (sslength sl))
        (setq ent (ssname sl index))
        (setq obj (vlax-ename->vla-object ent))
        (vlax-put-property obj 'Visible :vlax-true)
 (command ".undo" "end")
« Reply #4 on: September 14, 2005, 02:22:09 PM »
That should do it.
For fun I did this one, which will also ensure attributes / vertices are visible ---
(defun c:AllVisible ( / StartUndo Children ForceVisibility Main )
    (defun StartUndo ( document / enabled )
            (   (setq enabled (< 0 (getvar "undoctl")))
                (while (eq 8 (logand 8 (getvar "undoctl")))
                    (vla-endundomark document)
                (vla-startundomark document)
        enabled
    (defun Children ( ename / result )
        (if (assoc 66 (entget ename))
            (reverse
                (while
                    (/= "SEQEND"
                        (cdr
                            (assoc 0
                                (entget
                                    (setq ename
                                        (entnext ename)
                    (setq result (cons ename result))
    (defun ForceVisibility ( ename )
        (vl-catch-all-apply
            ;;  trap any errors, like
            ;;  object's layer locked
           '(lambda ()
                (vla-put-visible
                    (vlax-ename->vla-object object)
                    :vlax-true
        ;;  recursive call for child entities,
        ;;  like vertices and attributes
        (foreach child (Children ename)
            (ForceVisibility child)
    (defun Main ( document / ss i undoflag )
            (   (setq ss (ssget "x"))
                (setq undoflag (StartUndo document))
                (repeat (setq i (sslength ss))
                    (ForceVisibility
                        (ssname ss
                            (setq i (1- i))
                (if undoflag (vla-endundomark document))
    (Main
        (vla-get-activedocument
            (vlax-get-acad-object)
« Reply #5 on: September 14, 2005, 04:05:56 PM »
Thanks Michael.  :-)
« Reply #6 on: September 14, 2005, 04:08:09 PM »
My pleasure.
:kewl:
