Author Topic: blocks or entities on a specific layout  (Read 2783 times)
fxcastil
« on: September 13, 2005, 05:35:32 PM »
I have a drawing with multiple sheets (layout1-layout25.)
I am having problems creating a selection set of blocks on a specific layout.
I am using the AutoCad 2002 . I got the group filter code (410 layout names) from
an Autocad DXF reference manual. The filter code "410" is not working.
  ReDim intFltrCode(2) As Integer
  ReDim varFltrVal(6) As Variant
   intFltrCode(0) = 0     :   varFltrVal(0) = "INSERT"         ' get simple block references
   intFltrCode(1) = 2     :   varFltrVal(1) = "BlockName"     ' name of block to get
   intFltrCode(2) = 410  :   varFltrVal(3) = "Layout1"        ' get blocks in layout1 only
  ' Fill selection set "selSetAll" with filtered data
      objSelSet.Select Mode:=acSelectionSetAll, FilterType:=intFltrCode, FilterData:=varFltrVal
Does anyone know a way of creating a selection set of just blocks on a specific layout
using Lisp and the sendcommand ?
Fred C
fxcastil
Re: blocks or entities on a specific layout
« Reply #1 on: September 13, 2005, 05:53:33 PM »
I made a mistake in post the filter variables should have been as below in original post
The original question still applies
  ReDim varFltrVal(2) As Variant
   intFltrCode(2) = 410  :   varFltrVal(2) = "Layout1"        ' get blocks in layout1 only
Fred Castillo
Glenn R
« Reply #2 on: September 14, 2005, 06:44:49 AM »
Give up the 410 route...it doesn't work...even in Lisp.
I would suggest looping each layout's entities, that way if you come across your block you immediately know which layout it is on...or...create a filtered selection set for blocks, loop the selset and check the owner of the block reference, that way you can determine if it belongs to layout.
Here's another. You can reduce the number of places to look in your selection set by looking only at paperspace.
Here's an example:
Public Sub GrabPaperBlkRefs()
    Dim iDxfCode(0 To 2) As Integer
    Dim vDxfCodeVals(0 To 2) As Variant
    Dim pSelSet As AcadSelectionSet
    iDxfCode(0) = 0: vDxfCodeVals(0) = "INSERT"
    iDxfCode(1) = 2: vDxfCodeVals(1) = "YourBlockNameGoesHere"
    iDxfCode(2) = 67: vDxfCodeVals(2) = 1   ' Paperspace
    Set pSelSet = ThisDrawing.PickfirstSelectionSet
    pSelSet.Select acSelectionSetAll, , , iDxfCode, vDxfCodeVals
    MsgBox "Block references found: " & pSelSet.Count, vbInformation, "Block Reference Count"
End Sub
Cheers,
Glenn.
« Last Edit: September 14, 2005, 06:49:54 AM by Glenn R »
