Author Topic: Run a lisp from a script file is it possible  (Read 2707 times)
hyposmurf
« on: September 13, 2005, 08:02:50 AM »
Is there a way to run a lisp and then invoke a command from a script.I have a 100's of drawings where I want to run a lisp to clean them all up and set all objects to a particular color,then insert a similar title block and match the attributes of the blocks,zoom extents,close and save.
Re: Run a lisp from a script file is it possible
« Reply #1 on: September 13, 2005, 08:08:11 AM »
;;  script file
    (princ
        (strcat
            "Indeed, you can run lisp from scripts, in "
            "fact, it's all I put in scripts. Honestly, "
            "it's very powerful and flexible (imo).\n"
« Last Edit: September 13, 2005, 08:49:31 AM by MP »
hudster
« Reply #2 on: September 13, 2005, 09:07:20 AM »
EZscript pro allows you to run both scripts and lisps on selected files, without having to do any additional programming.
Andrew H
« Reply #3 on: March 17, 2006, 10:51:36 AM »
I'm just upgraded my computer and lost Ezscript Pro in the merger. Does anyone know where I can find it?
Andrew H
« Reply #4 on: March 17, 2006, 10:55:52 AM »
« Last Edit: March 17, 2006, 11:03:01 AM by Andrew H »
