Author Topic: Find & Replace Layer Names?  (Read 3285 times)
bman
« on: September 12, 2005, 02:41:26 PM »
Is there a way to find a layer(s) with a specific string and replace that string globally for multiple layers?
ex.... Find A & Replace with B
A-P-EOP
A-P-BNDY
A-P-CL
Change to this:
B-P-EOP
B-P-BNDY
B-P-CL
Re: Find & Replace Layer Names?
« Reply #1 on: September 12, 2005, 03:01:18 PM »
Take a look at the rename command.
bman
« Reply #2 on: September 12, 2005, 03:26:03 PM »
That works fine for adding a prefix to multiple layers, but I still have to go back & edit & remove the old prefix on about 150 layers.
Bob Wahr
« Reply #3 on: September 12, 2005, 03:48:25 PM »
in the rename dialog box
in Old Name, type a-*
in rename to, type b-*
click OK,
works fine for me
bman
« Reply #4 on: September 12, 2005, 05:13:59 PM »
I was selecting the layers in lieu of typing the wildcard :oops:
Thnaks for the tip!
Peter Jamtgaard
« Reply #5 on: September 12, 2005, 05:50:40 PM »
Try this
Peter Jamtgaard
(defun C:RenameLayers ()
 (setq strOld (getstring "\nOld String: ")
       strNew (getstring "\nNew String: ")
 (vlax-for objLayer
           (vla-get-layers
            (vla-get-activedocument
             (vlax-get-acad-object)
  (setq strLayerName (vla-get-name objLayer))
  (if (and
       (/= (vl-string-subst strNew StrOld strLayerName)
            strLayerName
       (not (tblsearch "layer" strLayerName))
    (vl-catch-all-error-p
     (vl-catch-all-apply
      'vla-put-name
      (list objLayer (vl-string-subst strNew StrOld strLayerName))
bman
« Reply #6 on: September 13, 2005, 08:03:43 AM »
I'm getting a syntax error when tryimh to load it
« Reply #7 on: September 13, 2005, 08:58:42 AM »
It's not you, the two if statements are malformed. I'm sure Peter will be around to fix it (and the local declarations) shortly -- I think he justed posted it real quick.
Peter Jamtgaard
« Reply #8 on: September 14, 2005, 08:53:13 AM »
Sorry for the error
Peter
(defun C:RenameLayers (/ objLayer strNew strOld )
 (vlax-for objLayer
           (vla-get-layers
  (if (and
            strLayerName
    (vl-catch-all-apply
     'vla-put-name
