Very interesting, as always...
I now remember you touching on this in previous threads. If I understand you correctly,
The attributes are added via a entmake for the INSERT and the locks out the casual user.
If they INSERT a new copy of that block it is without attributes.
The inserts with attributes are only accessible vis lisp.
This is very interesting stuff.. Thanks
Michael,
My original thought (original to me
) was to have a subroutine that you could send a list
of tag names along with the block ename and the routine would display a dialog box much
like the ATTEDIT dialog box. This would limit the access to attributes that you don't want
have the user change or attributes you are changing via your calling lisp routine.
This would be a universal routine & would work with your stealth attributes. On second thought
your stealth attributes would have no "Prompt" because it is stored in the block definition.
I think the "default Value" may be stored there as well.
Thanks Keith, I'll take a look....
I did not have an immediate need but was thinking about a universal subroutine.
Like i have nothing better to do!
