Author Topic: ATTEDIT my way?  (Read 10720 times)
Re: ATTEDIT my way?
« Reply #15 on: September 12, 2005, 06:03:41 PM »
Oooh I like the way you think.. :-D
Re: ATTEDIT my way?
« Reply #16 on: September 12, 2005, 06:06:52 PM »
Then it's mutual.
:-D
Re: ATTEDIT my way?
« Reply #17 on: September 12, 2005, 08:31:43 PM »
Here is version 1.02
But for the life of me I can't remember how to get rid of the frames around the vector images.
I have done it before but can't seem to get these to go away.
Re: ATTEDIT my way?
« Reply #18 on: September 12, 2005, 10:16:13 PM »
Maybe a text tile set to "*" or "" as appropriate instead of an image tile?
Re: ATTEDIT my way?
« Reply #19 on: September 12, 2005, 10:27:41 PM »
Got it. :-D
Now for the alignment. 8-)
PS Got that too.
« Last Edit: September 12, 2005, 11:02:18 PM by CAB »
Re: ATTEDIT my way?
« Reply #20 on: September 12, 2005, 11:08:11 PM »
I've frequently heard how difficult or laborious dcl programming is and I just don't see it. While a dcl based dialog can't challenge one defined by a more modern application like Delphi or Visual BASIC, they're a snap to make (and since they're plain text, can be written on the fly, though that's another discussion), particularly if you build sub assemblies to use in your dialog. Once you define sub assemblies the only thing, generally speaking, that varies from instance to instance is the key (and sometimes the label).
For example, in the dcl CAB authored it could be broken down like this (this would all be in one file, but breaking it up like this for discussion makes it easier to digest):
General dcl settings
//  general dcl settings
dcl_settings : default_dcl_settings
{ audit_level = 3; }
Sub assembly definitions:
//  sub assembly definitions
attribute_prompt : text {
    value = "Attribute Prompt" ;
    width = 30;
    fixed_width = true;
attribute_value : edit_box {
    edit_width = 34;
    edit_limit = 200;
    fixed_width = true;
attribute_state : image_button {
    height = 1;
    width  = 2;
    fixed_width = true;
    fixed_height = true;
    aspect_ratio = 1;
    color  = -15;
mybutton : button {
    width = 12;
    fixed_width = true;
Dialog definition:
//  dialog definition
MyAttEdit : dialog {
    label = "   MyAttEdit by CAB v1.0";
    :   text {
        value = "Block Name:  My Block";
        key   =  "txtblock";
        width = 50;
    :   text {
        value = "Page # ";
        key   =  "page";
        width = 10;
        alignment = right;
    spacer_1;
    //  use the sub assemblies we defined
    :   row {
        :   attribute_prompt { key = "txt1"; }
        :   attribute_value  { key =  "eb1"; }
        :   attribute_state  { key =  "im1"; }
    :   row {
        :   attribute_prompt { key = "txt2"; }
        :   attribute_value  { key =  "eb2"; }
        :   attribute_state  { key =  "im2"; }
    :   row {
        :   attribute_prompt { key = "txt3"; }
        :   attribute_value  { key =  "eb3"; }
        :   attribute_state  { key =  "im3"; }
    :   row {
        :   attribute_prompt { key = "txt4"; }
        :   attribute_value  { key =  "eb4"; }
        :   attribute_state  { key =  "im4"; }
    :   row {
        :   attribute_prompt { key = "txt5"; }
        :   attribute_value  { key =  "eb5"; }
        :   attribute_state  { key =  "im5"; }
    :   row {
        :   attribute_prompt { key = "txt6"; }
        :   attribute_value  { key =  "eb6"; }
        :   attribute_state  { key =  "im6"; }
    :   row {
        :   attribute_prompt { key = "txt7"; }
        :   attribute_value  { key =  "eb7"; }
        :   attribute_state  { key =  "im7"; }
    :   row {
        :   attribute_prompt { key = "txt8"; }
        :   attribute_value  { key =  "eb8"; }
        :   attribute_state  { key =  "im8"; }
    spacer_1;
    :   row {
        :   mybutton  { key = "ok";     label = "&OK";                         }
        :   mybutton  { key = "cancel"; label = "&Cancel";   is_cancel = true; }
        :   mybutton  { key = "prev";   label = "&Previous";                   }
        :   mybutton  { key = "next";   label = "&Next";                       }
        :   mybutton  { key = "help";   label = "&Help";                       }
This greatly speeds up dcl development, moreover, it makes maintenance a snap. Did ya note how I right aligned the key values for all the instanced sub assemblies? Makes it easy to assign and ensure the keys are correct (typically numerically incremented).
But more on maintenance ...
For example, if the attribute_prompt sub assembly width is found to be too wide, the width = 30; statement could be changed to width = 25; and all 8 instances will reflect same. Really takes the chore out of maintenance and makes it a lot easier to achieve consistancy throughout a dialog.
Another example: Say we decide to change the attribute_state sub assembly to a text tile from an image_button. No Problem:
/*attribute_state : image_button {
    height = 1;
    width  = 2;
    fixed_width = true;
    aspect_ratio = 1;
    color  = -15;
attribute_state : text {
    fixed_width = true;
    width = 1;
    is_bold = true;
Now all 8 instances of attribute_state are text tiles instead of image buttons (ps: I think if you made the image buttons just image tiles there may not be a border around them Alan).
Of course the code would have to reflect same:
(defun asterisk ( tile / x y )
    (set_tile tile "*")
    ;| <comment out former code>
    (setq
        X (dimx_tile tile)
        Y (dimy_tile tile)
    (start_image tile)
    (fill_image 0 0 x y -15)
    (mapcar 'vector_image; Color 1
        (list  5 1 1  0)
        (list  0 9 1  5)
        (list  5 9 9 10)
        (list 10 1 9  5)
        (list  1 1 1  1)
    (end_image)
    </comment out former code> |;
And:
(defun ast_clear ( tile / x y )
     (set_tile tile "")
    (setq
        X (dimx_tile tile)
        Y (dimy_tile tile)
    (start_image tile)
    (end_image)
Final tip: Read up on @include statement (in the context of dcl source files and subassembly discussion above).
:-D
« Last Edit: September 12, 2005, 11:38:19 PM by MP »
Re: ATTEDIT my way?
« Reply #21 on: September 12, 2005, 11:45:37 PM »
Great examples Michael.
So the Sub assemblies act like sub routines, that does help because many of the dialogs
I have created in the past have repetitive fields. I did figure out the image frame issue.
I agree, the DCL dialog is not that tough to create & sure makes for a more interesting interface
than the command line.
OK the @include gives you more power to call on sub assemblies.
I believe it's time for me to order the Developer's Guide. :-)
I'm tired of sifting through the on-line help.
Re: ATTEDIT my way?
« Reply #22 on: September 13, 2005, 12:49:28 PM »
Here is the revised code using Micheal's fine example of DCL code.
