Author Topic: Good one for expert...  (Read 2066 times)
Andrea
« on: September 09, 2005, 11:01:15 AM »
Hi all,
I know there is only expert here..
I'm just trying to make a LISP to get size image informations..
TIFF,GPJ,BMP...and so on..
is this possible ?
Keep smile...
Swift
Re: Good one for expert...
« Reply #1 on: September 09, 2005, 11:23:56 AM »
Outside of defun I don't know any lisp. What you need to do though, if I understand correctly, is open a binary file and see how large the image it contains is. So you need to know where in the file to look for this data, have a look at http://freeimage.sourceforge.net/intro.html
Andrea
« Reply #2 on: September 09, 2005, 11:45:32 AM »
wooooooo!!
a little complicaated for a newbi like me..
Keep smile...
Bob Wahr
« Reply #3 on: September 09, 2005, 11:58:07 AM »
Are the raster images in drawings already or do you want to get this info from files?  If they are in a drawing, VBA can get you that info.  If not, it probably still could.  There might well be a lisp solution also but to quote a former co-worker, when your only tool is a hammer, all problems look like nails.
« Reply #4 on: September 09, 2005, 12:25:12 PM »
Quote from: AutoCAD Help
Image group codes
Group code
 Description
100
 Subclass marker (AcDbRasterImage)
90
 Class version
10
 Insertion point (in WCS)
DXF: X value; APP: 3D point
20, 30
 DXF: Y and Z values of insertion point (in WCS)
11
 U-vector of a single pixel (points along the visual bottom of the image, starting at the insertion point) (in WCS)
21, 31
 DXF: Y and Z values U-vector (in WCS)
12
 V-vector of a single pixel (points along the visual left side of the image, starting at the insertion point) (in WCS)
22, 32
 DXF: Y and Z values of V-vector (in WCS)
13
 Image size in pixels
DXF: U value; APP: 2D point (U and V values)
23
 DXF: V value of image size in pixels
340
 Hard reference to imagedef object
70
 Image display properties:
1 = Show image
2 = Show image when not aligned with screen
4 = Use clipping boundary
8 = Transparency is on
280
 Clipping state: 0 = Off; 1 = On
281
 Brightness value (0-100; default = 50)
282
 Contrast value (0-100; default = 50)
283
 Fade value (0-100; default = 0)
360
 Hard reference to imagedef_reactor object
71
 Clipping boundary type. 1 = Rectangular; 2 = Polygonal
91
 Number of clip boundary vertices that follow
14
 Clip boundary vertex (in OCS)
DXF: X value; APP: 2D point (multiple entries)
NOTE 1) For rectangular clip boundary type, two opposite corners must be specified. Default is (–0.5,–0.5), (size.x–0.5, size.y–0.5). 2) For polygonal clip boundary type, three or more vertices must be specified. Polygonal vertices must be listed sequentially
24
 DXF: Y value of clip boundary vertex (in OCS) (multiple entries)
Andrea
« Reply #5 on: September 09, 2005, 01:58:15 PM »
se7en
hey !!  this is pretty close....thanks
but is this possible to get info befor inserting the image file ?
Keep smile...
