Author Topic: CUI madness!!  (Read 2200 times)
CUI madness!!
« on: September 09, 2005, 08:23:57 AM »
Trying to add a button to my custom toolbar, when I select an icon from the list I get the following dialog. Any idea why this happens?
deegeecees
Re: CUI madness!!
« Reply #1 on: September 09, 2005, 10:50:57 AM »
Support paths?
Andrea
Re: CUI madness!!
« Reply #2 on: September 09, 2005, 01:33:47 PM »
yeah.....
every time same problem..
make sure that your icon folder are in the support path and then....
recompile your CUI file...
Keep smile...
Re: CUI madness!!
« Reply #3 on: September 09, 2005, 01:42:02 PM »
If the icons show up in the cui then isn't reasonable to presume the icons/dll are in the path?
BTW, these are *not* icons I created.
Re: CUI madness!!
« Reply #4 on: September 09, 2005, 01:52:20 PM »
The *cough* fix is to right-click on the icon!!
deegeecees
Re: CUI madness!!
« Reply #5 on: September 09, 2005, 01:56:27 PM »
I was using 2006 a couple months back, and played around with custom menus. I found the "new" cui interface to be a bit cumbersome. I believe that it is a step towards xml but they haven't figured how to incorporate legacy mnu's seamlessly yet. I'll have to venture a guess that there is some type of overlapping in their code that is causing this error (could be wrong of course). Anyway, long story short, was pressed for time so, I ended up just creating an mnu.
OK, then I won't post. *cough* :wink:
Andrea
Re: CUI madness!!
« Reply #6 on: September 09, 2005, 06:27:49 PM »
didn't know your icon was there....
but try this..
http://discussion.autodesk.com/thread.jspa?threadID=409112
Keep smile...
Re: CUI madness!!
« Reply #7 on: September 19, 2005, 08:44:40 AM »
Nope!
The right-click trick only worked for the one edit of the CUI ( confusing user interface ), now it's doing the same thing again.   :realmad:
