Author Topic: Text Rotation  (Read 5944 times)
Craig
Text Rotation
« on: September 07, 2005, 12:55:53 PM »
Does anyone know what the variable for text rotation is?
Something like (getvar 'textsize) but for the text rotation/angle
TIA
tombu
  • ByLayer=>Not0
Re: Text Rotation
« Reply #1 on: September 07, 2005, 01:13:39 PM »
Having spent too much time looking for it I'm pretty sure there isn't one.  Please someone tell me I'm wrong.
Tom Beauford P.S.M.
CottageCGirl
Re: Text Rotation
« Reply #2 on: September 07, 2005, 01:40:48 PM »
^C^C-attedit;;;;;\;P;\A;\N;
sorry, havent had time to fully explore the new ins and outs of the new stuff
CottageCGirl
Re: Text Rotation
« Reply #3 on: September 07, 2005, 01:42:10 PM »
ooops sorry, I'm in block mode, thats the move/rotate for attributes (maybe someone can still use it) :oops:
Craig
Re: Text Rotation
« Reply #4 on: September 07, 2005, 01:45:25 PM »
I find it hard to believe that it shows up in a list but it's not accessible as some type of variable.
What I want is I've written a program that places an identifier on a line with the distance of the selected line and places the text at a certain distance off the line, at the angle of the line and in the middle of it. What I need is to be able to reset the text rotation back to zero. It seems fairly simple thing to do but in my searching I've yet to find anything that will do this.
Craig
Re: Text Rotation
« Reply #5 on: September 07, 2005, 01:52:30 PM »
Thinkg more I guess a work around is to place the text at zero and auto rotate it to the correct angle. Not what I want to do but if no else has an answer I guess it will have to do.  :?
Craig
Re: Text Rotation
« Reply #6 on: September 07, 2005, 02:02:46 PM »
This worked fine even though it's not what I wanted to do.
(command "text" "bl" mecGetPoint mecTxtSize "0" mecLineLength)
(command "rotate" "l" "" mecGetPoint mecAngle)
Crank
Re: Text Rotation
« Reply #7 on: September 07, 2005, 02:25:13 PM »
Try this:
(command ".text" "bl" mecGetPoint mecTxtSize mecAngle mecLineLength)
LE
Re: Text Rotation
« Reply #8 on: September 07, 2005, 02:28:52 PM »
See if this quick code does what you are looking for.
Load the code in your drawing session, type any text or mtext and use: (get_txtrot_angle)
To read the rotation angle.
HTH
(if (not (getenv "TextRotationAngle"))
  (setenv "TextRotationAngle" "0.0"))
(defun savetxtrotangle (reactor params / ename obj)
  (if (and (wcmatch (car params) "TEXT,MTEXT")
   (setq ename (entlast))
   (wcmatch (cdadr (entget ename)) "TEXT,MTEXT"))
      (setq obj (vlax-ename->vla-object ename))
      (rtos (vla-get-rotation obj) 2 8)))))
(if (not text_rotation_angle_reactor)
  (setq text_rotation_angle_reactor
(vlr-editor-reactor
   "text rotation angle"
   '((:vlr-commandended . savetxtrotangle)))))
(defun rtd (a) (* (/ a pi) 180.0))
(defun get_txtrot_angle ()
  (rtd (atof (getenv "TextRotationAngle"))))
Craig
Re: Text Rotation
« Reply #9 on: September 07, 2005, 03:00:05 PM »
Try this:
Thats the way I had it at the start. Thats the reason for this thread, to be able to set the text rotation back to zero. If I use the one you show the text is set to that angle throughout the session unless I manually change it.
All I wanted was to set the text rotation to zero after using something like
(setvar 'textrotation 0)
even though that variable does not exist
Bob Wahr
Re: Text Rotation
« Reply #10 on: September 07, 2005, 03:01:32 PM »
you could put your text in along the line, then put in a piece of text at 0 and erase it.  Sloppy, ugly, nasty, but as a last resort.
LE
Re: Text Rotation
« Reply #11 on: September 07, 2005, 03:03:52 PM »
All I wanted was to set the text rotation to zero....
O....I shoud read first....
Craig
Re: Text Rotation
« Reply #12 on: September 07, 2005, 03:07:08 PM »
Thanks, this works fine, just didn't want it that way
Craig
Re: Text Rotation
« Reply #13 on: September 07, 2005, 03:08:14 PM »
Thanks for the replies
Re: Text Rotation
« Reply #14 on: September 07, 2005, 04:04:49 PM »
Here is one way to set text angle to zero.
(defun c:txt2ang0 (/ ss i obj ename)
  (prompt "\nSelect text to change angle to zero")
  (and (setq ss (ssget '((0 . "TEXT,MTEXT"))))
       (setq i -1)
       (while (setq ename (ssname ss (setq i (1+ i))))
         (vlax-put-property obj 'Rotation 0.0)
