Author Topic: [POLL] Monitor Resolution  (Read 7819 times)
Re: [POLL] Monitor Resolution
« Reply #15 on: September 07, 2005, 12:13:13 PM »
I travel so much that my laptop has become my only working computer. It is a 15"LCD with max resolution of 1024. It is still clearer than my old 17" CRT, and with no flicker it's a lot easier on my eyes.
Graldensblud
« Reply #16 on: September 07, 2005, 12:24:16 PM »
well i'm awkward and have my CRT set to 1152x whatever that works out as. No poll option for that! 1280x1024 is too small for my eyesight, 1024x276 too big to work with. :roll:
« Reply #17 on: September 07, 2005, 12:28:18 PM »
1280X1024 dual 19" lcd's
« Reply #18 on: September 07, 2005, 04:28:32 PM »
1280 x 1024 dual 19" lcd's at work.
1024 x 768 single 17" lcd at home.
Big Boi
« Reply #19 on: September 07, 2005, 05:48:21 PM »
What do you guys do to talk your emloyer into buying you two monitors. There ain't enough butts to kiss around here to get that.  :?
Chuck Gabriel
« Reply #20 on: September 07, 2005, 06:40:35 PM »
At work I run two 19" CRT's at 1024x768.
At home I run one 19" LCD at 1280x1024.
JCappiello
« Reply #21 on: September 08, 2005, 08:24:23 AM »
Compaq Laptop (15.1" @ 1400) on a port replicator with OLD NEC MutliSync P1150 @ 1600.
Lobbying for a nice Dell 19" Flat Panel.
Bob Wahr
« Reply #22 on: September 08, 2005, 03:18:33 PM »
The two options I picked were 1024 and 1280 because my resolution is 1024X1280.  Single 19" right now dual 19" in the near future.
MvdP
« Reply #23 on: September 08, 2005, 03:30:15 PM »
1280x1024 ona 21" CRT.
« Reply #24 on: September 08, 2005, 04:10:39 PM »
hmmmm ..
37 responses
42 resolutions
30 monitors
oh, dear ...
« Reply #25 on: September 08, 2005, 05:55:04 PM »
Good poll Kerry, I believe that's a record for theswamp.  8-)
« Reply #26 on: September 08, 2005, 06:58:17 PM »
Well, I didn't choose a single or dual monitor monitor so that is part of the discrepancy .. after all you didn't say we HAD to ...
« Reply #27 on: September 08, 2005, 07:05:49 PM »
Hi Keith,
Thats not the issue ..
I'd assumed that if Dual wasn't noted then single applied.
ie : because 15 selected dual the remaining 22 use single
The variance comes from some people voting for 2 resolutions.
ie : if 37 voted there should be 37 resolutions selected not 42
« Reply #28 on: September 08, 2005, 07:12:05 PM »
Ah .. I see ... Maybe they have 2 monitor resolutions .. one at home and one at work ...
« Reply #29 on: September 08, 2005, 07:17:28 PM »
Perhaps ..
I thought I had it covered
Question: What's your current monitor resolution ?
I guess I hadn't allowed for a few things.
