Author Topic: Toolbars keep moving  (Read 2425 times)
adrian
« on: September 01, 2005, 10:18:19 PM »
I am using 2006 and am having problems with some custom toolbars having a mind of their own.  I open acad up and place all my toolbars into the correct position, then quit acad.  When I go back in, some toolbars are in different positions.  Does anyone know how the location of the toolbar is saved?  And yes locking them doesnt help, it only means I have to unlock them to put them in the right spot.
Adrian
whdjr
« Reply #1 on: September 01, 2005, 11:09:59 PM »
The Acad session you are making the changes in, make sure that profile name is the same one that your short-cut is loading.
adrian
« Reply #2 on: September 01, 2005, 11:19:41 PM »
I make the toolbars in the right spot, then save the profile.  I then selected the "set current" button which then put them back in the wrong spots.  So not even the right profile is helping me.
Thanks for your reply.
whdjr
« Reply #3 on: September 01, 2005, 11:27:20 PM »
Yes, but make sure your Acad Shortcut on your desktop is loading your saved profile.
adrian
« Reply #4 on: September 01, 2005, 11:32:15 PM »
How do you do that?  I know it is a variation in the shortcut area, but not sure where.
I am not sure it will help though if the profile I want is not loading correctly when I go "set current"
whdjr
« Reply #5 on: September 01, 2005, 11:41:58 PM »
Right click on your Acad Desktop Icon, then select properties.  In the 'target' input box it contains the path for the Autocad executable, the profile, and other switches.  The text between the parens after the /p should be the name of the saved profile.
"C:\Program Files\Autodesk Architectural Desktop 2006\acad.exe"  /p "<<Unnamed Profile>>"
adrian
« Reply #6 on: September 02, 2005, 12:35:18 AM »
Thanks for your reply, but this didnt help.  Any other ideas??
Crank
« Reply #7 on: September 02, 2005, 01:48:53 AM »
If the toolbars are from different .cui's then make a copy of the toolbar that gives you problems to the main .cui and use the copy.
whdjr
« Reply #8 on: September 02, 2005, 10:03:02 AM »
Quote from: adrian
Sorry, I don't.
MarkO
« Reply #9 on: September 02, 2005, 10:26:32 AM »
Look into WORKSPACE in the help file. This may be of use.
Andrea
« Reply #10 on: September 02, 2005, 05:50:52 PM »
You can also pu a clip or scotch tape ! 8)
Keep smile...
Bob Wahr
« Reply #11 on: September 02, 2005, 06:30:15 PM »
set LOCKUI to 1
« Reply #12 on: September 02, 2005, 07:45:32 PM »
OOOhhh .. look Jurg has a twin in MarkO
