that why stadardisation is important.
No matter how poeple insert block....
the final result must be the same.
That why in 2002..I have created in our office a insertion block module.
this module is completely "cutomisable" by drafter and can share
block path with other workmates.
Also, this module allow user to insert block without thinking !!
I mean without searching where the block is..
It auto-calculate the insertion scale, Paper mode, Model mode, or in any MVIEW in any scale
It also allow user to classify any block depending the department, client and categorie.
It create a standard insertion file who is shared with others.
It diplay a tumbnail of the block. (this was added only in AutoCAD 2006...about time).
So, now after showing how my module work....lot of deparment work with it.
and in the same act....stopped to have different insertion block in same project....and waste time to re-adjust some drawings..
This module was created to work for our office....
I need to make some modification before sharing this with you guys...(and girls).
So let me know of some of you are interested.
seya !
