If your users are in Autocad 2004 or newer then I would say go for the tool pallette setup.
Right now you should focus on moving all blocks to 0,0,0, setting their base to 0,0,0, putting them on layer 0 (at least that's the way I do it) and setting them up so they can be scaled per dimscale. As you save them your naming system will come in. The way we used to name blocks was e-l1x4, e-lex1, e-lexl, e-lexr, etc. where e is for the dept. (electrical), l is for system (lighting) and the rest is a short description (1x4 fixture, ex1 single face exit, exl exit with left arrow, exr exit with right arrow).
If you intend to go the way of slides you may want to check out some other sites first. I know Afralisp will be back in a bit and Kenny had some lisp routines for doing slides and slide libraries.
If all else fails you could set them up for tool pallettes but use Design Center instead. Down and dirty but, it gets the job done.
