I am trying to find the error in this lisp. It happens at the blockit function. Can someone please point it out to me and tell me what I need to do to fix it.
Thank you
(defun C:WINTRIM ( / *error* stq wq pick1 pick2 pick3 pick4 tpnt1 tpnt2 bpnt)
(setvar "cmdecho" 0)
(setq o_osmode (getvar "osmode")
o_clayer (getvar "clayer")
*error* sillerr
blss nil
(if (not stype) (setq stype "TS"))
(if (not width) (setq width 3))
(prompt "\nType: TS-Trim Sill/TSS-Trim Sill Surround/BS-Brick Surround/BR-Brick Rowlock")
(initget "TS TSS BS BR")
(if (/= (setq stq (getkword (strcat "\nSpecify type [TS/TSS/BS/BR]<" stype ">: "))) nil)
(setq stype stq)
(initget "3 4 6 8")
(if (/= (setq wq (getkword (strcat "\nSpecify width [3/4/6/8]<" (itoa width) ">: "))) nil)
(setq width (atoi wq))
((= stype "TS")
(initget 1)
(setq pick1 (getpoint "\nSelect left corner: "))
(initget 1)
(setq pick2 (getpoint pick1 "\nSelect right corner: "))
(setq tpnt1 (polar pick1 (angle pick2 pick1) 0.75)
tpnt2 (polar pick2 (angle pick1 pick2) 0.75)
bpnt (polar pick1 (angle pick1 pick2) (/ (distance pick1 pick2) 2))
(drawit stype tpnt1 tpnt2 width nil)
(blockit stype tpnt1 tpnt2 bpnt width nil blss)
((= stype "TSS")
(initget 1)
(setq pick1 (getpoint "\nSelect top left corner: "))
(initget 1)
(setq pick2 (getpoint pick1 "\nSelect bottom left corner: "))
(initget 1)
(setq pick3 (getpoint pick2 "\nSelect bottom right corner: "))
(initget 1)
(setq pick4 (getpoint pick3 "\nSelect top right corner: "))
(setq tpnt1 (polar pick2 (angle pick3 pick2) (+ width 0.75))
tpnt2 (polar pick3 (angle pick2 pick3) (+ width 0.75))
bpnt (polar pick1 (angle pick1 pick4) (/ (distance pick1 pick4) 2))
(drawit stype pick1 pick2 width nil)
(drawit stype pick3 pick4 width nil)
(blockit stype tpnt1 tpnt2 bpnt width (+ (distance pick1 pick2) width) blss)
((= stype "BR")
(initget 1)
(initget 1)
(setq bpnt (polar pick1 (angle pick1 pick2) (/ (distance pick1 pick2) 2)))
(drawit stype pick1 pick2 width 2.750)
(blockit stype pick1 pick2 bpnt width nil blss)
((= stype "BS")
(initget 1)
(initget 1)
(initget 1)
(initget 1)
(setq tpnt1 (polar pick2 (angle pick3 pick2) width)
tpnt2 (polar pick3 (angle pick2 pick3) width)
(drawit stype pick1 pick2 width 3.0)
(drawit stype tpnt1 tpnt2 width 2.750)
(drawit stype pick3 pick4 width 3.0)
(setvar "clayer" o_clayer)
(setvar "osmode" o_osmode)
(setvar "cmdecho" 1)
;Draw Routine
(defun drawit (typ pt1 pt2 wdth lnspac / reclgth ang pt3 pt4 realnum remain
intnum offset lnpt1 lnpt2
(setq reclgth (distance pt1 pt2)
ang (angle pt1 pt2)
pt3 (polar pt1 (- ang (/ pi 2)) wdth)
pt4 (polar pt2 (- ang (/ pi 2)) wdth)
(setvar "clayer" "0")
(setvar "plinewid" 0)
(setvar "osmode" 0)
(command "-color" 6 "-linetype" "Set" "ByBlock" "")
(command "_.pline" pt1 pt3 pt4 pt2 "C")
(if (not blss) (setq blss (ssadd (entlast))) (ssadd (entlast) blss))
(if (/= lnspac nil)
(setq realnum (rtos (/ reclgth lnspac) 2
(setq remain (distof (substr realnum (+ (vl-string-search "." realnum) 1)) 2))
(if (>= remain 0.53125)
(setq intnum (+ (atoi realnum) 1))
(setq intnum (atoi realnum))
(setq offset (/ (- reclgth (* intnum lnspac)) 2))
(setq offset (+ lnspac offset))
(command "-color" 1)
(repeat (- intnum 1)
(setq lnpt1 (polar pt1 ang offset))
(setq lnpt2 (polar pt3 ang offset))
(command "_.line" lnpt1 lnpt2 "")
(command "-color" "ByLayer" "-linetype" "Set" "ByLayer" "")
;Block Routine
(defun blockit (typ pt1 pt2 basept wdth hgt ss / )
(setvar "filedia" 1)
(if (/= hgt nil)
(setq blk_name (strcat (itoa wdth) typ "-" (rtos (distance pt1 pt2) 2 1) " X " (rtos hgt 2 1) ".dwg"))
(setq blk_name (strcat (itoa wdth) typ "-" (rtos (distance pt1 pt2) 2 1) ".dwg"))
C:\Documents and Settings\bcrouse\Desktop\Library R & D Blocks\Window Trim" blk_name))
(command "_.move" ss "" basept "0,0,0")
(if (/= (findfile path) nil)
(command "_.-wblock" path "Y" "" "0,0,0" ss "")
(command "_.-wblock" path "" "0,0,0" ss "")
(command "_.-insert" path "S" 1 basept 0)
;Error Routine
(defun sillerr (msg)
(prompt (strcat "\nError: " msg))
)[/code]
