Hudster,
Questions to consider:
What is the Min Angle?
Do you always start your pick with the larger duct?
When you pick, are you picking the end of two parallel lines for pick 1 & 2?
Are the two lines for the smaller duce already there?
Do you know the size of the smaller duct without measuring it?
Is the reducer always asymmetrical?
I like the direction Will was thinking. A dynamic shape where you anchor the two
corners with picks 1&2 then stretch pick 3 using the Near snap to get one side of
the smaller duct if the two ducts have a common centerline. If centerline is not
the same a fourth pick would be needed.
Just think out loud.
