resistance is futile, you will be assimilated...
Ok Howi, I give up...
Actually it reads almost EXACTLY like the book ...
EXACTLY like the help file would I say...
As you know, my English is a little wobbly and that's the reason that I use sometimes 'prefabricated' phrases. In the actual case I think it's legitimate to use the help statement because it's exactly what I know about 'On Error Resume Next'.
It reads as if straight from a book and would have been nice if it mentioned the fact that it does clear the error or ...
Does not.
This fact is part of my sample:
You've to clear the Err object to avoid unexpected results.
Note:
End Sub, End Function, Exit Sub, Exit Function, Exit Property or Resume Next clears the Err object also...
Nodding.
Michael, could
that be the reason for your headache?
