Author Topic: Multi Sort  (Read 13601 times)
Multi Sort
« Reply #15 on: August 29, 2005, 12:06:14 PM »
OK as an exercise, here is my feeble attempt at rewriting my sort, stealing much of your code. :)
Still slower than yours but only slightly.
;; Function: tab_sort
;; Purpose : sort list of strings by the prefix then the first numbers found
;; AUTHOR  : Charles Alan Butler
;; Version : 2.0  08/29/05
;; Params  : tablst:    list of strings to sort
;; Returns : sorted list
(defun Num_Sort (tablst / newlst result tmp code codes padlen sub x
                 isdigit delist group )
  (defun isdigit (code) (< 47 code 58))
  (defun delist (lst / delst)
    (defun delst (lst / 1-list a)
      (while lst
        (if (listp lst)
          (if (and (listp (setq a (car lst))) a)
            (setq 1-list (append (delst a) 1-list))
            (setq 1-list (cons a 1-list))
          (setq 1-list (cons lst 1-list))
        (setq lst (cond ((listp lst) (cdr lst))))
      1-list
    (reverse (delst lst))
  ;; group ascii into numbers & non numbers
  (defun group (newlst / newlst2 tab code result grplst tmplst)
    (foreach tab newlst
      (setq tmplst nil
            result nil
      (foreach code (reverse tab)
          ((null tmplst)
           (setq tmplst (list code))
          ((isdigit code)
           (if (isdigit (car tmplst))
             (setq tmplst (cons code tmplst))
             (setq
               result (cons tmplst result)
               tmplst (list code)
          ((if (isdigit (car tmplst))
             (setq
               tmplst (list code)
      (if tmplst
        (setq result (cons tmplst result))
      (setq newlst2 (cons result newlst2))
  ;;        S T A R T   O F   R O U T I N E
  (setq newlst (mapcar
                 '(lambda (x)
                    (vl-string->list x)
                 tablst
  (setq newlst (group newlst))
  ;;  set max length of numerical sequience
  (setq padlen 0)
  (mapcar
    '(lambda (sub)
       (mapcar
         '(lambda (codes)
            (if (isdigit (car codes))
              (setq padlen
                     (max padlen
                          (length codes)
         sub
    newlst
  ;; pad numerical list
  (setq newlst
         (mapcar
           '(lambda (sub)
              (mapcar
                '(lambda (x)
                   (if (isdigit (car x))
                       (while (< (length x) padlen)
                         (setq x (cons 48 x)
                       x
                     x
                sub
           newlst
  ;;  remove grouping
  (setq newlst (mapcar 'delist newlst))
  ;;  convert back to string
                 '(lambda (x)
                    (vl-list->string x)
                 newlst
  ;;  combine new & old list
  (setq tablst (mapcar 'cons tablst (reverse newlst)))
  ;;  sort on new list
  (setq tablst (vl-sort tablst '(lambda (e1 e2) (< (cdr e1) (cdr e2)))))
  ;;  reduce list to original items
  (setq tablst (mapcar 'car tablst))
  tablst
) ; end defun
