Sub Fishies()Dim objGroup As AcadGroupDim objGroups As AcadGroupsDim intGroup As IntegerDim intTemp As IntegerDim objSelSet As AcadSelectionSetDim objSelSets As AcadSelectionSetsDim entGrouped() As AcadEntityOn Error GoTo ErrorControl Set objSelSets = ThisDrawing.SelectionSets Set objGroups = ThisDrawing.Groups KillSet "Grouper" Set objSelSet = objSelSets.Add("Grouper") objSelSet.SelectOnScreen For Each objGroup In objGroups intTemp = Right(objGroup.Name, 1) If intTemp > intGroup Then intGroup = intTemp End If Next objGroup ReDim entGrouped(0 To objSelSet.Count - 1) For intTemp = 0 To UBound(entGrouped) Set entGrouped(intTemp) = objSelSet.Item(intTemp) Next intTemp Set objGroup = objGroups.Add(intGroup + 1) objGroup.AppendItems entGroupedExitHere:Exit SubErrorControl: Select Case Err.Number Case Else MsgBox "''" & Err.Description & "'' error has occured in Fishies" & vbCrLf GoTo ExitHere End Select End SubFunction KillSet(strSet As String) Dim objSelSet As AcadSelectionSet Dim objSelSets As AcadSelectionSets Set objSelSets = ThisDrawing.SelectionSets For Each objSelSet In objSelSets If objSelSet.Name = strSet Then ThisDrawing.SelectionSets.Item(strSet).Delete Exit For End If NextEnd Function
