Hi all,
Ok there it is..
I'm trying to make a special routine to underline selected text and Mtext without using %%u....
so I need to make 2 lines at different distance under the text.
the problem is.
I can't found a way to detect the endpoint of text.
so if the selected text is Bottom Left justification, I need to get the Bottom Right point...but don't know how.
and so on...
any suggestion will be appreciated.
thanks.
