Author Topic: Hatch by polyline Question  (Read 15908 times)
V-Man
  • I exist therefore I am! Finally Retired!
« on: August 23, 2005, 09:40:14 AM »
Hiya guys,
I'm trying to write a lisp to count how many polylines there are in a drawing and based on that info create a hatch individually for each. How can I accomplish this?
I have this so far....
(defun C:HP ()
(command "_undo" "_g")
  (setq ss (ssget "X" '((-4 . "<AND")(0 . "LWPOLYLINE")
                                 (-4 . "AND>"))))
  (if ss
      (setq n (1- (sslength ss)))
        (repeat n
           (command ".hatch" "ANSI31" "200" "" (ssname ss n)))))
   (command "._undo" "_end")
Any thoughts definately welcome!
AutoCAD 9 - 2023, AutoCADMap 2008 - 2010, Revit 2012 - 2022, Autocad Civil 3D 2023
whdjr
« Reply #1 on: August 23, 2005, 10:08:24 AM »
Well I think in order to hatch a polyline it needs to be closed, so a check for that should be included in your ssget list:  (70 . 1).
You really don't need the <ANDs in your list unless you are polling for the same dxf number.
whdjr
Re: Hatch by polyline Question
« Reply #2 on: August 23, 2005, 10:13:52 AM »
Quote from: dvarino
(defun C:HP ()
                                 (-4 . "AND>"))))
  (if ss
        (repeat n
Another way you could write the IF statement without using 'prog' is like this
(if ss
  (repeat (setq n (sslength ss))
    (setq n (1- n))
Just another way to do the same thing. :)
V-Man
« Reply #3 on: August 23, 2005, 10:20:56 AM »
Ok, this is what I got now.
Command: (defun C:HP ()
(_> (command "_undo" "_g")
(_>   (setq ss (ssget "X" '(0 . "LWPOLYLINE")(70 . 0)))
(_> (if ss
((_>   (repeat (setq n (sslength ss))
(((_>     (setq n (1- n))
(((_>     (command ".hatch" "ANSI31" "200" "" (ssname ss n))
(((_>   )
((_> )
(_>    (command "._undo" "_end")
(_>   (princ)
(_> )
I get this when i run the routine.
; error: bad argument type: consp 0
V-Man
« Reply #4 on: August 23, 2005, 10:24:36 AM »
Ah, found my mistake
(defun C:HP ()
  (setq ss (ssget "X" '((0 . "LWPOLYLINE")(70 . 0))))
(if ss
    (setq n (1- n))
But this till will not hatch....
whdjr
« Reply #5 on: August 23, 2005, 10:29:51 AM »
Your ssget function has to be passed a list:
yours:  (setq ss (ssget "X" '(0 . "LWPOLYLINE") (70 . 0)))
mine:   (setq ss (ssget "X" '((0 . "LWPOLYLINE") (70 . 0))))
whdjr
« Reply #6 on: August 23, 2005, 10:30:30 AM »
(70 . 1)
whdjr
« Reply #7 on: August 23, 2005, 10:38:21 AM »
Ok here is the problem.  You need an extra return at the end of your command statement:
(command ".hatch" "ANSI31" "200" "" (ssname ss n) "")
whdjr
« Reply #8 on: August 23, 2005, 10:42:52 AM »
Just remember that
(70 . 0)  selects non-closed polylines (however the ending segments still need to cross for the hatch to display)
and
(70 . 1) selects closed polylines.
If you want it to do both the just take out the (70 . ?) all together.
V-Man
« Reply #9 on: August 23, 2005, 01:07:41 PM »
Thanks for the help, much appreciated. I knew that I was close, I just needed a kick in the head....
Thnx again
« Reply #10 on: August 23, 2005, 04:40:54 PM »
Just to throw in my $0.02.....if a Pline's linetypegen is set to on, bit 128 is added to the group 70 code......you really should use it like this:
(setq ss (ssget "x" '((0 . "POLYLINE,LWPOLYLINE")(-4 . "&")(70 . 1))))
The "&" forces a bitwise comparison looking for the 1 bit.
« Reply #11 on: August 23, 2005, 05:16:38 PM »
Provided for fun, as is, complete with warts & freckles ...
(defun c:HatchEm ( / _HatchIt ss i space )
    (defun _HatchIt ( space object / hatch err )
        (setq err
            (vl-catch-all-apply
               '(lambda ()
                    (setq hatch
                        (vlax-invoke
                            space
                           'AddHatch
                            acHatchStyleNormal ;; pattern type
                            "ANSI31"           ;; pattern name
                            :vlax-false        ;; associativity
                            AcHatchObject      ;; hatch object type
                    (vlax-invoke
                        hatch
                       'AppendOuterLoop
                       (list object)
                    (vlax-invoke hatch 'Evaluate)
        (if (vl-catch-all-error-p err)
            (princ
                (strcat
                    "Entity handle:"
                    (vla-get-handle object)
                    " caused this error: "
                    (vl-catch-all-error-message err)
        (   (setq ss
                (ssget
                   '(   (0 . "lwpolyline,polyline")
                        (-4 . "&")
                        (70 . 1)
            (setq space
                (vlax-get-property
                    (vlax-get-property
                        (vlax-get-acad-object)
                       'ActiveDocument
                    (if (eq 1 (getvar "cvport"))
                       'PaperSpace
                       'ModelSpace
                (_HatchIt
                    space
                    (vlax-ename->vla-object
                        (ssname ss (setq i (1- i)))
dubb
« Reply #12 on: August 23, 2005, 05:27:45 PM »
that was a great code...
**i might be hijacking but,
how do i make it so that i draw some lines first then the hatch automatically goes in. without having to create a polyline and then running the routine.
LE
« Reply #13 on: August 23, 2005, 06:28:42 PM »
Quote from: dubb
Are you thinking of vlisp reactors???
dubb
« Reply #14 on: August 23, 2005, 06:46:48 PM »
Quote from: LE
Quote from: dubb
well im a noob to lisp..but i have developed a few programs.
will this type of routine that im talking about, require the use of reactors? i hear reactors are difficult to work with.
