Author Topic: Question 15 answers go here  (Read 5476 times)
Dinosaur
« Reply #30 on: August 23, 2005, 11:39:13 AM »
Quote from: Bob Wahr
Are you talking about filet with a 0 radius?
Yes, that was the way I did it . . . sloppy but it worked.
LE
« Reply #31 on: August 23, 2005, 11:40:35 AM »
No fillet.... it was [back to 85 - 87] and still works that command now...  it works just for lines and with orthomode on only.
Dinosaur
« Reply #32 on: August 23, 2005, 11:45:14 AM »
You can do that with the change command
LE
« Reply #33 on: August 23, 2005, 11:47:14 AM »
Quote from: Dinosaur
Yes.... after I mention the hints.... anyway did not want to mess on this thread....
Later.
PDJ
« Reply #34 on: August 23, 2005, 12:17:26 PM »
Umm, fillet 0 works with more than lines and ortho mode doesn't matter.. I've been using it for at least 15 years..
Tom
« Reply #35 on: August 23, 2005, 05:46:25 PM »
"I know is not related my reply here, but anyone here remember how to extend or trim lines without the trim or extend command?"
Lengthen
Bob Wahr
« Reply #36 on: August 23, 2005, 05:55:03 PM »
lengthen will extend but not trim, you have to give it a positive non-zero value.  I had forgotten that command though.
« Reply #37 on: August 23, 2005, 06:06:03 PM »
lengthen will extend but not trim, ..... .
Lengthen ->Delta will accept Negative Values
Lengthen -> DYnamic will shorten .. and accepts Direct Distance Entry.
Tom
« Reply #38 on: August 23, 2005, 06:08:02 PM »
Sorry but your wrong you can give it a negative number eg -100(or you can in 2004) and it will shorten the line or arc thus trimming it
Bob Wahr
« Reply #39 on: August 23, 2005, 06:16:30 PM »
My bad, when I tried it, I gave it a negative for the total length.  Gee, I wonder why that didn't work.
LE
« Reply #40 on: August 23, 2005, 06:20:08 PM »
hmmm..... was Lengthen part of R9 ???.. I do not remember that command....
« Reply #41 on: August 23, 2005, 06:23:23 PM »
Quote from: LE
First in R13 I think Luis .
