Author Topic: Question 15 answers go here  (Read 5478 times)
« on: August 22, 2005, 08:48:19 PM »
In AutoCAD, name two ways to rename a layer?
« Reply #1 on: August 22, 2005, 09:19:21 PM »
Well, the obvious is to use the layer dialog and the other would be .. I ain't tellin .. let someone else do it .... but I do know
Dinosaur
« Reply #2 on: August 22, 2005, 09:34:46 PM »
Quote from: Keith
You mean like the clunky old RENAME command?
TR
« Reply #3 on: August 22, 2005, 09:38:58 PM »
Quote from: Dinosaur
Quote from: Keith
Thats what I was thinking.
« Reply #4 on: August 22, 2005, 10:20:18 PM »
Possible Alternative at the Command Line :
Command: -rename
Enter object type to rename
[Block/Dimstyle/LAyer/LType/Style/Tablestyle/Ucs/VIew/VPort]: la
Enter old layer name: xx1
Enter new layer name: xx2
Dinosaur
« Reply #5 on: August 22, 2005, 11:29:52 PM »
That was the only way to do it through r10 or r11.  The fancy dialog boxes didn't show up until r12.  There was even a shortened command name for it.
Any guesses what it was for a bonus?
« Reply #6 on: August 22, 2005, 11:58:08 PM »
Are you talking the layer command, as in the ddl alias for ddlmodes?
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
Dinosaur
« Reply #7 on: August 23, 2005, 12:01:37 AM »
No, the alternate command name for "RENAME"
edit
thinking about it, it probably was one of the built in alias's instead of a real command.
« Reply #8 on: August 23, 2005, 12:05:20 AM »
Ok, good thing I didn't post ddlmodes then. You mean ren then?
Dinosaur
« Reply #9 on: August 23, 2005, 12:08:01 AM »
Quote from: MP
Correct, I will donate to you whatever I won in helping guess question 15's answer.
« Reply #10 on: August 23, 2005, 12:11:48 AM »
Quote from: MP
There's prizes? Adjusting scorecard.
I'll double it back to you: what was the utility that was the basis for the MS DOS's 'doskey' utility that gave one command line aliases (and a stack) at DOS?
/thread hijack.
Dinosaur
« Reply #11 on: August 23, 2005, 12:14:31 AM »
I used mrkeys and qkeys.  I don't know their heritage, but someone brought them in very early on.  I still have copies hidden away somewhere.
« Reply #12 on: August 23, 2005, 12:20:31 AM »
akeys ??
« Reply #13 on: August 23, 2005, 12:21:38 AM »
The original that I recall was called ... suitably enough ... ALIAS. IIRC it originated from PC Magazine but I cannot find any decent web reference. Somewhere I have it on a floppy with a TSR ascii chart and some other invaluable tools I used to load into a ram disk; oh those were the days. This would be very late 80's (guess).
Dinosaur
« Reply #14 on: August 23, 2005, 12:26:26 AM »
I would not be surprised if the guy that brought in ours had not written it himself.  He had written most of DCA's functions in lisp routines for r10 386 ca 1991.
