Author Topic: (challenge) nth remover  (Read 16579 times)
SMadsen
« Reply #30 on: January 21, 2004, 06:02:23 PM »
Didn't say it wasn't a smart way to do it. It is smart!
SMadsen
« Reply #31 on: January 21, 2004, 06:08:59 PM »
Quote from: Keith
Did you notice that it didn't require the setting of any additional variables.
Yep. Slick and short. Limited to first occurence of an item but slick and short nonetheless.
If only there was a NTH_MEMBER function. That's why the idea of (repeat i (setq lst (cdr lst))) - only it didn't turn out as clean as yours.
daron
« Reply #32 on: January 21, 2004, 06:27:11 PM »
I was trying to use member at first. I wanted the member of the nth + 1 part of the list. That was easy, but the first half is where I was having trouble; gathering the list 1- to the nth of the list.
« Reply #33 on: January 21, 2004, 09:22:11 PM »
Quote from: SMadsen
Like this?
(defun nthMember (lst item / cntr pos)
  (mapcar
    '(lambda (x)
      (if (not cntr) (setq cntr 0) (setq cntr (1+ cntr)))
       (if (eq x item)
         (setq pos cntr)
    lst
  pos
Command: (nthmember '(1 2 3 4) 2)
> 1
Command: (nthmember '(1 2 3 4) 1)
> 0
Command: (nthmember '(1 2 3 4) 6)
> nil
Command: (nthmember '(1 2 3 4) 3)
> 2
SMadsen
« Reply #34 on: January 22, 2004, 04:26:42 AM »
Nah, I meant more like: get the rest of the list from nth index
(defun nthmem (lst i)
  (cond ((zerop i) lst)
        ((repeat i (setq lst (cdr lst))))
(nthmem '(0 1 2 3 4 5) 2)
(2 3 4 5)
(nthmem '(0 1 2 3 4 5) 0)
(0 1 2 3 4 5)
(nthmem '(0 1 2 3 4 5) 4)
(4 5)
(reverse (nthmem (reverse '(0 1 2 3 4 5)) 4))
(0 1)
« Reply #35 on: January 22, 2004, 09:21:08 AM »
Oh, Got cha. ...hey thats cool.
« Reply #36 on: January 22, 2004, 09:31:52 AM »
NEXT..................
since i didn't get to play in this one, i'm ready for another. :D
« Reply #37 on: January 22, 2004, 09:39:44 AM »
Another?!  ...Ok let me try to think up another idea.
