Enjoyed reading this thread, but didn't find anything elegant to change a dimension style to a new font (unless I'm missing something about VBA). So, here is my rough n ready script.
This is intended to run in a drawing in which there already exists the dim style you want, and the desired effect will be:
1)to modify that dim style to display romans font, and
2) change all dimensions to that dim style
You'll of course have to edit the text style name "ROMANS" and dim style name "DIM-ROMANS" as desired. You may also have to manually adjust the dimscale of the drawing after running the script, depending on the scale called for in the dimstyle setting, but the font will be changed as intended.
Hope this is helpful to someone. Comments welcome.
cheers
jc
________________________________________________
undo
m
undo
m
-style
ROMANS-AY
romans
0
.8
0
n
n
n
-dimstyle
restore
AYDIM
dim
dimtxsty
ROMANS-AY
exit
ssx
e
dimension
dim
up
p
exit
_____________________________________________________________________
