Author Topic: A text font lisp  (Read 18791 times)
BREZI
A text font lisp
« on: August 17, 2005, 08:55:02 AM »
Anybody got a lisp routine to change all fonts to be the same in a drawing?
much obliged!
 :D
A text font lisp
« Reply #1 on: August 17, 2005, 09:19:20 AM »
qselect!!
BREZI
A text font lisp
« Reply #2 on: August 17, 2005, 09:37:19 AM »
Cheers use that already its good.
Tell my problem, we get loads of architects drawings with loads of fonts, our standard procedure we change all fonts to romans.
I was think I could use ezscript to run a lisp on afolder of drawings during lunch time or somthing like that.
Im still learning lisp, not good at doing my own yet, I can edit and tweak existing ones no probs.
A text font lisp
« Reply #3 on: August 17, 2005, 09:44:47 AM »
BREZI,
One solution that doesn't require modifying the drawings is to remove ALL the font definitions other than ROMANS, and update your font mapping file accordingly.
.. That way when you get revisions to the reference drawings you wont have to repeat the process.
.. .. and it can be demonstrated that you haven't made modifications to design documents .. which may, or may not, be important one day.
BREZI
A text font lisp
« Reply #4 on: August 17, 2005, 10:06:29 AM »
Good idea, but;
Unfortunately I have to produce presentation drawings sometimes, and then we use all of the fancy drawings, and we have to print architects drawings exactly as issued for record purposes.
thanks :o)
A text font lisp
« Reply #5 on: August 17, 2005, 10:10:41 AM »
Sure ..
Options, -> Files -> Font File Location
Have 2 folders, one for presentation, one for your special needs.
Flip a switch, you have them all back.
... something you wont have if you change the Font physically
kwb
David Hall
  • Automatic Duh Generator
A text font lisp
« Reply #6 on: August 17, 2005, 10:10:48 AM »
I dont have a LISP version, but I have a vba routine that will do it.  It can be called from a script as well
BREZI
A text font lisp
« Reply #7 on: August 17, 2005, 10:15:59 AM »
Quote from: CmdrDuh
That would be cool.
cheers.
David Hall
A text font lisp
« Reply #8 on: August 17, 2005, 10:16:18 AM »
I can upload the file if you need it. Here is the code
Option Explicit
Public Sub ChangeTextToRomans()
  Dim objSelected As Object
  Dim objTxt As AcadText
  Dim objstyle As AcadTextStyle
  Dim objLayer As AcadLayer
  Dim objSelSet As AcadSelectionSet
  Dim intAnswer As Integer
  On Error GoTo ErrControl
Set objstyle = ThisDrawing.TextStyles.Add("ROMANS")
objstyle.fontFile = "romans.shx"
objstyle.Width = 1#
  Set objSelSet = ThisDrawing.SelectionSets.Add("Text")
  objSelSet.Select acSelectionSetAll
    For Each objSelected In objSelSet
        If TypeOf objSelected Is AcadText Then
        Set objTxt = objSelected
            If UCase(objTxt.StyleName) <> "ROMANS" Then
            objTxt.StyleName = "ROMANS"
            objTxt.ScaleFactor = 1#
            Else
            End If
        End If
    Next
  ThisDrawing.SelectionSets.Item("Text").Delete
  ThisDrawing.Application.Update
Exit_Here:
  Exit Sub
ErrControl:
  MsgBox Err.Description
End Sub
David Hall
A text font lisp
« Reply #9 on: August 17, 2005, 10:20:44 AM »
your script would look something like
open "your dwg name" (command "-vbarun" "E:/TextToRomans.dvb!ThisDrawing.ChangeTextToRomans") qsave close
all you would have to do is change paths to match yours
BREZI
A text font lisp
« Reply #10 on: August 17, 2005, 10:47:08 AM »
Thats great cheers for the help!
David Hall
A text font lisp
« Reply #11 on: August 17, 2005, 10:48:49 AM »
Glad it worked!  You might need to tweak some of the settings like width factor or preset height.  Also, I didn't put in the error checking to see if the Selection Set existed or not, so that can be added.  I have that code if you need it.
BREZI
A text font lisp
« Reply #12 on: August 17, 2005, 11:11:47 AM »
Dumb question, but how I turn that code into a dvb file?
Never done that before, only worked with lisp & scripts.
A text font lisp
« Reply #13 on: August 17, 2005, 11:40:26 AM »
Hey cmdrduh,
I'm trying to set a font to arial.ttf but it wont work??
Set objstyle = ThisDrawing.TextStyles.Add("Arial")
objstyle.fontFile = "arial.ttf"
objstyle.Width = 1#
Doest this not work with True Type Fonts?
Thanks,
Ron
David Hall
A text font lisp
« Reply #14 on: August 17, 2005, 11:49:06 AM »
Brezi, I'll upload the file, but in a nutshell, open VBAman, create a new project, and add to ThisDrawing or a module of your choice.  Ronjonp, ill post that in a minute
