i take that back daron. i was thinking that because we got some drawings with the walls hatched in and each segment is a block. we want to make all work that is not ours light but they make it a real hassle. so i guess that's my addition to the list
We have to do the same thing,everything from the Architect has to be on a certain color so it displays faded and our work stands out when plotted and viewed on screen.
Here's the lisp I use,we have everything set to color 8.
;* CLEANUP.LSP With Attribute Cleanup enabled
; by Dominic Panholzer
; Flack + Kurtz Consulting Engineers
; San Francisco
; April 23, 1992
;* This routine prepares drawings received from clients
;* to be used for background xrefs. It will change every layer
;* color to the designated background color, specified by the
;* variable NEW_CLR below. It will also change all drawing
;* entities to color BYLAYER. Next all blocks will be checked
;* for attribute subentities with color designations. These will
;* all be changed to NEW_CLR. Finally, all block subentities
;* which are not color BYLAYER will be changed to NEW_CLR.
(defun c:cln ( / NEW_CLR, CMD, TBDATA, ENAME, EDATA, ENXT)
(setq NEW_CLR 8 ; Color 8 = grey.
NEW_CLR (cons 62 NEW_CLR) ; Set dotted pair for subst.
CMD (getvar "CMDECHO") ; Save command echo setting.
SS (ssget "X") ; Selection set of all ents.
SSLEN (sslength SS) ; Length of selection set.
CNT 0 ; Counter = 0.
);setq
(setvar "CMDECHO" 0) ; Set command echoing off.
; Use this to select color to be changed to
; else 8 will be used
(setq INPUT (getint "Please enter color number <8>: "))
(setq NEW_CLR (CONS 62 INPUT))
);if
; Change entities' color to BYLAYER
; and all layers to NEW_CLR
(command "CHPROP" SS "" "COLOR" "BYLAYER" "") ; Change color of all ents.
(command "LAYER" "COLOR" (cdr NEW_CLR) "*" ""); Change layer color.
; CLEANUP ATTRIBUTES
(while (< CNT SSLEN)
(setq ENAME (ssname SS CNT) ; Step through each entity.
EDATA (entget ENAME)
);setq
(if (= (cdr (assoc 0 EDATA)) "INSERT") ; If it is a block
(if (setq ENXT (entnext ENAME)) ; and if it has a subentity
(if (= (cdr (assoc 0 (entget ENXT))) "ATTRIB") ; which is an attrib,
(ch_color ENAME NEW_CLR) ; then change its color.
);if
);if
);if
(setq CNT (1+ CNT)) ; Go to the next entity.
);while
; CLEANUP BLOCK LIST
(setq TBDATA (tblnext "BLOCK" T)) ; Retreive the first block
(while TBDATA ; from symbol table.
(setq ENAME (cdr (assoc -2 TBDATA))) ; Retrive its entity number.
(ch_color ENAME NEW_CLR) ; Change its color.
(setq TBDATA (tblnext "BLOCK")) ; Get the next block.
);while
(command "REGEN") ; Regenerate the drawing.
(setvar "CMDECHO" CMD) ; Reset command echo.
(princ) ; Finish cleanly.
);defun
; -------------------- COLOR CHANGING FUNCTION -------------------
; Changes ENAME's color to NEW_CLR
(defun ch_color ( ENAME, NEW_CLR / EDATA, OLD_CLR)
(setq EDATA (entget ENAME)) ; Get entity data.
(while EDATA
(if (setq OLD_CLR (assoc 62 EDATA)) ; If entity has a color,
(setq EDATA (subst NEW_CLR OLD_CLR EDATA)) ; subst. new color
(entmod EDATA) ; and update entity.
);progn
);if
(setq ENAME (entnext ENAME)) ; Retreive subentity.
(if ENAME ; If it exists repeat process,
(setq EDATA nil) ; else return.
);if
(if (= (cdr (assoc 0 EDATA)) "SEQEND") ; needed for attributes but
(setq EDATA nil) ; causes problems with block
) ; cleanup
);while
);defun
