Author Topic: First VB.NET application......ssssllllloooooowwwwww  (Read 24154 times)
Bob Wahr
Re: First VB.NET application......ssssllllloooooowwwwww
« Reply #15 on: November 02, 2005, 03:42:15 PM »
Is there a place to share files here in the swamp?  I have a write up that I did a while back that goes into detail on all of this.
http://www.theswamp.org/lilly_pond/ make a youish folder
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #16 on: November 02, 2005, 04:13:35 PM »
Thank you Mr. Wahr!
I've uploaded the file.  http://www.theswamp.org/lilly_pond/BobbyCJones/Calling%20your%20code%20from%20AutoCAD.doc
**WARNING**   This only applies to code written against the AutoCAD COM API.  This will not work with the new managed API.
Bobby C. Jones
Jeff_M
  • C3D user & customizer
« Reply #17 on: November 02, 2005, 05:40:57 PM »
Ok .. here is a quick rundown ... <snipped all the good stuff>
If you need an example, let me know ...
Thanks Keith. It is finally starting to make sense to me. I'll give it a try and if I get stuck I'll be back asking for that example.
And Thanks to Bobby, too, for posting that document. I'll be reading that tonight. Oh, and thanks for resurrecting this thread. It might be the kick I needed to get back into the learning mode.
« Reply #18 on: November 02, 2005, 06:39:56 PM »
Thanks for sharing Bobby.
Could you do [us] a favour .. Could you state explicitly in the document which Programming IDE, API <done> and ACAD Version that code is meant to suit.
If [we] don't, it's likely that the thread will fill with posts like "I copied the code and want to know Why doesn't ....
I'm guilty of missing this too ...
Sorry if this seems a PITA.
Great to see you here ..
Regards
Bobby C. Jones
« Reply #19 on: November 03, 2005, 10:34:00 AM »
Regards
Sure, not a problem.  I wrote this using VS.NET 2003 with AutoCAD 2004 as my target version.  However, the ideas presented in it are valid for any version of Acad with a COM API.  Likewise, all versions of .NET are capable of COM Interop and can be used.
Also, sorry for the odd formatting in the document.  I pulled it out of a larger piece where it all looked much better :)
Look at that <PointingOverThere>  You can d/l it from the AUGI web site.  Although it looks like they have included a bunch of stuff from some other class too...what's up with that?
http://www.augi.com/education/auhandouts/2003/CP12-1.zip
« Last Edit: November 03, 2005, 12:10:56 PM by Bobby C. Jones »
Bobby C. Jones
Jeff_M
« Reply #20 on: November 05, 2005, 03:21:09 PM »
 :pissed: :realmad: :pissed: :realmad:
OK, what else can MS do to make this harder for me? Every help file I can find, including the one that came with my Visual Studio .NET 2003, says
Visual Studio and then select File> New> Project. In the New Project dialog select Visual Basic Projects for the Project Type. Select “Class Library” template
So I try this and there is no Class Library Template to be found.....so now I go off to search my computer and the 'net......on the MS website I find this
The Class Library template is not available in the Standard Edition of Visual Basic .NET.
What da hell? Does this mean I can't create DLL's with the Standard Edition? What good IS the Standard edition?
I'm starting to think knitting is looking better as a hobby than is this programming for Acad.  :lmao:
« Reply #21 on: November 05, 2005, 03:41:16 PM »
If I recall correctly that is indeed the case Jeff; sorry.
Jeff_M
« Reply #22 on: November 05, 2005, 03:46:03 PM »
OK, I admit it....I'm a putz and don't know jack....
I just found the AutoCAD_NET_labs.zip file on the Autodesk website that has a number of examples and yup, I CAN build DLL's (I just built the HelloWorld command.... :woot: ). Now to just make my own little template or, at least, figure out what the DLL requires vs the EXE that my projects default to......
Carry on.....
« Reply #23 on: November 05, 2005, 03:52:45 PM »
Maybe what I'm thinking is you can't create type libraries without the Enterprise version or equivalent.
Oh coffee truck ...
Jeff_M
« Reply #24 on: November 05, 2005, 05:13:51 PM »
Thanks, Michael, for keeping me thinking here. I don't know how much more coffee I can drink today. Just when I think I'm getting somewhere, *BLAM* !!!! Now where did THAT brick wall come from? Time to switch to some asprin & water.
All I can say is "It's a good thing it's a cold & rainy day and the wife is at work. I just might make some progress today."
« Reply #25 on: November 05, 2005, 05:42:57 PM »
<Jeff_M=Blue>Thanks, Michael, for keeping me thinking here.
I believe the words you're looking for are "Thanks for the red herring Michael".
There's a limit? Adjusting scorecard.
But that's what makes it fun, right? <seg>.
Time to switch to some aspirin & water.
There are many mornings I start with a hearty bowl of milk and aspirin.
Know 'xactly what you mean, Linda works Saturdays, I write proposals same lately.
Good luck Jeff, hope you get what you want done today++.
« Last Edit: November 05, 2005, 05:48:45 PM by MP »
Troy Williams
« Reply #26 on: November 06, 2005, 09:14:58 AM »
Jeff, here is a link that may help you out with the class library template.
Jeff_M
« Reply #27 on: November 06, 2005, 12:06:06 PM »
Thanks, Troy! I'll be testing it out with my app later on today.
Glenn R
« Reply #28 on: November 06, 2005, 07:51:12 PM »
For those that don't know, install the ObjectARX Wizard from the ObjectARX SDK.
Apart from adding in all the aRX stuff, it ALSO adds in an "Autodesk Managed CS Project" (and VB) under "Visual C# Projects" and VB respectively.
Cheers,
Glenn.
Ken Alexander
« Reply #29 on: November 07, 2005, 09:55:01 AM »
Hey Jeff,
More and more familiar people.  I'm not providing any solutions, cause I can't......I myself have just recently jumped in to .NET (with both feet and a rock tied to them).
I was wondering if there was an MSDN for the MSDN <g>  Having tons of fun learning this though.
Ken Alexander
