Author Topic: Dynamic block examples  (Read 21410 times)
Guest
Re: Dynamic block examples
« Reply #30 on: April 03, 2008, 01:08:40 PM »
We can't use wipeouts here.  :-(
DARN YOU REPRODESK!!!   :realmad:
« Reply #31 on: April 03, 2008, 01:15:24 PM »
Use a solid hatch pattern.  Set it to back, and put the color 255.  This has worked for me before wipeouts.
Guest
« Reply #32 on: April 03, 2008, 01:20:20 PM »
What did you have for settings in the CTB file for 255?
Josh Nieman
« Reply #33 on: April 03, 2008, 01:22:13 PM »
255 will print black normally unless you go out of your way to do otherwise.  I use an RGB color to do so.  254,254,254 usually.  RBG colors ignore CTBs so you'd be safe.  I do that for company logos too where we actually need color.  Better than the boss going and turning random ACI entries into a color-plot and saving it locally only... think I finally broke him of that, though, when I showed him how easy it was to pick a RGB color.
« Reply #34 on: April 03, 2008, 01:53:08 PM »
I think it was set to use object color.
Edit:  Attached an example.  There is a hatch patter sent to back, and color 255.  In my ctb file I set it to 'use object color'.  In the preview it looks a little gray, but as you can see it prints white.
« Last Edit: April 03, 2008, 01:57:18 PM by T.Willey »
