Author Topic: Lisp to start a acad function  (Read 4084 times)
Anton
« on: January 19, 2004, 04:33:19 AM »
In Acad2002 there is a function in a (tools?) pulldown menu to extract attributes.
Is there a way to call this function with a lisp file?
The goal is to run a lisp file, and at a certain point to start that other lisp file to extract attributes.
I'm a newbie to lisp programming and this should be very easy to you, but for me it's really ????
Please help!
Anton
SMadsen
« Reply #1 on: January 19, 2004, 05:36:46 AM »
Hi Anton,
Welcome to theSwamp forums.
I can't remember if EATTEXT was part of A2K2, but if so then you can just call it as any other built-in command.
If you're referring to Express Tools' ATTOUT command then it's based on an AutoLISP routine with the command prefix "C:".
You can call it from within your own AutoLISP routine with (C:ATTOUT).
For example
(defun runMyAttExtraction (/ attm)
  ;; do something ... e.g.
  (setq attm (getvar "ATTMODE"))
  (setvar "ATTMODE" 2)
  ;; call ET's ATTOUT
  (C:ATTOUT)
  ;; do something else ... e.g.
  (setvar "ATTMODE" attm)
« Reply #2 on: January 19, 2004, 07:17:02 AM »
Hi Anton, Welcome.
Anton
thanks!
« Reply #3 on: January 20, 2004, 05:07:03 PM »
As an old cadalog forumuser I switched over to this board.
I love to see all those names again who helped me the early days.
I think I will still need some help with lots of things.
Somebody has to ask questions, right? :)
Thanks again!
« Reply #4 on: January 20, 2004, 06:33:44 PM »
yeppers...
