Author Topic: (challenge) A Little Math Question  (Read 2431 times)
tcdan
« on: August 01, 2005, 02:00:07 AM »
Newbies will be able to do this as well as advanced LISPers.
Write a line of code (or more) that will set the NEArest object snap without modifying any of the other object snap settings.
It's a fun little math excercise :)
Crank
« Reply #1 on: August 01, 2005, 02:40:12 AM »
(SETVAR "OSMODE" (BOOLE 6 (GETVAR "OSMODE") 512)); on/off
(SETVAR "OSMODE" (- (GETVAR "OSMODE") -512 (LOGAND (GETVAR "OSMODE") 512))); on
or:
(SETVAR "OSMODE" (+ (LOGAND (GETVAR "OSMODE") 31231) 512)); on
« Reply #2 on: August 01, 2005, 07:27:52 AM »
Quote from: tcdan
... Write a line of code that will set the NEArest object snap without modifying any of the other object snap settings ...
(setvar "osmode"
    (logior 512
        (getvar "osmode")
tcdan
« Reply #3 on: August 01, 2005, 11:11:36 AM »
Wow that's great!  I knew you guys could come up with a faster way than this:
    (setq snaps (getvar "osmode"))
  (if ( = (rem (/ snaps 512) 2) 0) (setvar "osmode" (+ 512 snaps)))  ;; set 'nearest' snap
daron
« Reply #4 on: August 01, 2005, 12:19:18 PM »
Crank's first one's my personal favorite. It sets and unsets it. Boole is Coole.
« Reply #5 on: August 01, 2005, 01:27:39 PM »
Here is a neat little trick that doesn't require setting osnaps ... you can override it in lisp to the one you require.
(setq pt (osnap (getpoint "\nSelect point") "_nearest"))
Crank
« Reply #6 on: August 04, 2005, 08:29:27 AM »
Quote from: Keith
That's probably the best solution. You don't have to restore the osnap when you finish the function.
But if you do want to change the OSMODE then it's just an OR-operation, so this should also work:
(SETVAR "OSMODE" (BOOLE 7 (GETVAR "OSMODE") 512)); on
Jürg Menzi
  • Oberegg, Switzerland
« Reply #7 on: August 04, 2005, 08:39:52 AM »
(osnap pnt "_nea") fails on some objects. Therefore I use this solution:
(defun MeEntSel ( / CurEnt CurObj NeaPnt)
 (if (setq CurEnt (entsel "\nSelect object: "))
   (setq CurObj (vlax-ename->vla-object (car CurEnt))
         NeaPnt (if (vl-position
                     (vla-get-ObjectName CurObj)
                    '("AcDbArc" "AcDbCircle" "AcDb2dPolyline")
                 (vlax-curve-getClosestPointToProjection
                  CurObj
                  (trans (cadr CurEnt) 1 0)
                  (trans (getvar "VIEWDIR") 1 0 1)
                 (osnap (cadr CurEnt) "_NEA")
   (list (car CurEnt) (trans NeaPnt 0 1))
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
