Author Topic: Mtext Word wrap removal  (Read 6104 times)
Re: Mtext Word wrap removal
« Reply #15 on: April 14, 2006, 11:09:49 AM »
The problem with Mtext, and dxf codes is that if the string is too long, then you need to check if it has a dxf code of 3 (for continueing the string).  I would reccomend that you use the ActiveX properties to get the text string.
Example using what Mark posted.
(defun c:blastReturns (/ rm-returns ent entlst str new_str TxtObj)
 (defun rm-returns (str)
   (while (wcmatch str "*\\P*")
     (setq str (vl-string-subst " " "\\P" str))
   str
 (if (setq ent (car (entsel "\nSelect MTEXT: ")))
     (setq entlst  (entget ent)
;   str    (cdr (assoc 1 entlst))
   str (vla-get-TextString (setq TxtObj (vlax-ename->vla-object Ent)))
   new_str (rm-returns str)
;     (setq entlst
;    (subst (cons 1 new_str) (assoc 1 entlst) entlst)
;     (entmod entlst)
    (vla-put-TextString TxtObj new_str)
Krushert
  • FREE BEER Tomorrow!!
« Reply #16 on: April 14, 2006, 11:40:36 AM »
;     (setq entlst
;     (entmod entlst)
It works, though I had to remove the Semi-Colans that you had place in the code.
It as crashing @  line that contain the code [ "new_str (rm-returns str) ]
Don't ask me why  :?  but it works.
« Reply #17 on: April 14, 2006, 11:55:44 AM »
Weird, but as long as you got it working.
You're welcome for the little I did, it's still Mark's code.
Krushert
« Reply #18 on: April 14, 2006, 12:04:00 PM »
Thanks to all of you.  Everytime I am come here I learn something.  And thanks for some of the cool routines too. :kewl:
