Yeee-Hawww.
;;then move the text to the midpoint of the dimension line
We're not going to move the text to the midpoint of the DIMENSION line, but we are going to get that point. This is the point we're about to get.
Okay Dan. I'm going to spell it out for you now. I see that you tried and since you can't look into my mind to see where I'm going to go with this this'll take a load off. Okay, let's see; when I was testing this, I was looking into finding the midpoint of the dimline by using 10 and 11. 11 isn't the middle of the dimension line as I understand it, but the middle of the dimension text. So, if the text is not in the middle of the dimension line, you're going to have trouble. Now, if you move your dimensions and you want the text we're moving below the dimtext, then we're going to have to go the GC11 route, but for now, I'd like to assume you're not concerned with that and we're going to go a slightly different direction, which will give you knowledge of some more functions that as you begin to understand, you'll want to use commonly. Also, I found some quirky things happening when trying to subtract some values from pt10 and pt11. So, to avoid the conflict I had, we're going to alter the course and make sure we get the points we need which by your criteria, is the middle of the dimension line.
Okay, I said I'd spell it out for you, so here it is. We do need GC10, but let's look at GC14. GC14 is origin point along the same line as 10, so you have a common line to all dimensions here. I just stumbled across a little issue. I went back and tested something and it appears we'll need GC13 as well, but let's not worry about that right now. I'll explain later. Right now, I want you to look at a couple of help topics: angle and polar. Read up on these and see if you can make sense of them. I can't find polar in any of Stig's lesson's. If you can great, otherwise just try and tell us what you find concerning polar and angle and we can move ahead.
and proud of myself for making the leap into learning how to do for myself.
I'm sure many of us are too. As well, when you do have a more sound understanding, you'll be able to pitch in with some help to others, which is the greatest benefit.
