Author Topic: cutting and pasting viewports  (Read 10286 times)
« Reply #15 on: January 17, 2004, 08:32:02 AM »
I haven't tried that ..... I just started wblocking the parts I wanted to snag and insert them in the other drawing.
ELOQUINTET
« Reply #16 on: January 17, 2004, 12:32:37 PM »
you guys have been busy here. well i am used to using ctrl c and v for cutting and pasting and it doesn't seem to work doing it that way sometimes but the right click method worked this time. thanks guys
hyposmurf
« Reply #17 on: January 17, 2004, 12:58:44 PM »
There's so many different ways to copy something and they all perform differently.Like you can copy with basepoint from the right click or with out basepoint,you can issue the command copy or hold down ctrl and drag the item etc
daron
« Reply #18 on: January 18, 2004, 12:17:03 AM »
Quote from: hyposmurf
What if you disable the object enablers from showing,does that clear the problem up?
Don't know, but changing passwords and restarting my computer and setting some security for internet use after reading an article on vbdesign the night before, which I can't find now, worked.
hyposmurf
« Reply #19 on: January 18, 2004, 05:23:07 AM »
Weird,do you reckon somoeone else was signing as you? :evil:
daron
« Reply #20 on: January 19, 2004, 09:16:18 AM »
If so, I hope I caught it soon enough. Hope not.
hudster
« Reply #21 on: January 21, 2004, 04:33:47 PM »
I use a program called WINM8, it gives you about 50 spaces on your clipboard, so cutting and pasting becomes ever so easy.
Only drawback, it can only do copy with basepoint for one item, the rest it loses the information on.
Apart from that it's great.  I've copied all my standard notes onto it, and i just click and paste the entire note into any drawing.
