Author Topic: Wall Style Cleanup help  (Read 4727 times)
One Shot
« on: July 20, 2005, 11:19:25 AM »
I am trying to figure out how to get these wall to cleanup properly. Can some tell me what I am doing wrong. Please ref. the attach file. When you look at the components, The priorities match and the slab ledge are all equal with the stem wall.
The reason for this is to make the walls styles to work for the less experienced CAD TECH dealing with wall styles. Because it is hard to know the experience of our outside Consultants do to turnover.
Please ref. the Lilly Pond under  One Shot for the Wall Style.dwg.  The clouded area is where I am having problems.  You will also see 2 simple sections to show you what the wall style represent.
Thank you,
Brad
[/url]
whdjr
« Reply #1 on: July 20, 2005, 02:40:25 PM »
One Shot,
In the properties for that Tool icon you can set the Cleanup Radius to something bigger than 0".
By default Autodesk sets it to 0", go figure!?!?
Basically the Wall justification lines have to interset in order to clean up the default way.
