Author Topic: Breaking an infinite Loop other than ctrl-alt-del.  (Read 901 times)
damn
« on: June 13, 2024, 09:06:54 PM »
Damn!
I'm stuck in a loop, haven't for saved 1.5hrs stupid me....yeah yeah, save early save often.  I don't want to lose my latest updates.
Any other way other than ctrl-alt-del?
Damn.
Re: Breaking an infinite Loop other than ctrl-alt-del.
« Reply #1 on: June 14, 2024, 03:29:56 AM »
If you have VLIDE open, you can go to Debug > Abort Evaluation; otherwise, try Ctrl+C.
didier
  • expatrié
« Reply #2 on: June 16, 2024, 05:49:24 AM »
Bonjour
Ok with Lee Mac.
But, sometimes this is not working and strangely, it worked with this combination of keys CTRL+Pause
Amicalement
eternal beginner ...
my english is not fluent ...
damn
« Reply #3 on: June 16, 2024, 09:35:07 PM »
Thanks Lee, Didier,
The abort evaluation has never worked for me in this case, believe me I tried.  I only use that to break when animating.
I used to use Ctrl-Break, current keyboard doesn't have the break key.  Just found a work around to add the break key.
I think you're actually utilising the Break key Didier as your key would be Pause/Break.
I'll try Ctrl-C.
Damn
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: June 16, 2024, 11:08:08 PM »
Asked same question long time ago and I am out to 40+ years lisping, sorry Lee but Ctrl+C has never worked for me but I was not running inside VLIDE would have to be Blade for me. Will try Ctrl+Break do have that key.
(setq x 1)
(repeat 100000
(princ (strcat "\n" (rtos (setq x (1+ x)) 2 0)))
NOPE none of these.
Ctrl+C
Ctrl+break
Break
Pause
Fn+pause
CodeDing
« Reply #5 on: June 18, 2024, 11:31:26 AM »
A long time ago, I ran into a recommendation for another language but it has worked ever since, for almost anything.
hold Alt + Esc
Senior CAD Tech & AI Specialist
Need AutoLisp help?
Try my custom GPT 'AutoLISP Ace'
damn
« Reply #6 on: June 22, 2024, 01:01:59 AM »
hold Alt + Esc
Didn't work for me.
