Use a hash table to quickly delete completely overlapping entities
What is a Hash Table?A hash table (or hash map) is a data structure that provides a mechanism for storing key-value pairs, allowing for fast data retrieval. Each key is processed through a hash function, which computes an index (or hash code) into an array of buckets or slots. The key-value pair is then stored in the corresponding bucket. The fundamental operations of a hash table, such as insertion, deletion, and search, typically have an average time complexity of O(1), making them very efficient.
Why is Using a Hash Table to Delete Identical Entities in ARX Highly Efficient?1. Fast Lookups:- The primary strength of a hash table is its ability to perform quick lookups. When deleting duplicate entities, you can compute a hash for each entity and check if that hash already exists in the table.
- If the hash already exists, it means the entity is a duplicate and can be marked for deletion.
- If the hash does not exist, the entity is added to the table.
2. Efficient Handling of Collisions:- In a hash table, collisions occur when two different entities produce the same hash code. Advanced hash table implementations efficiently handle collisions using techniques like chaining (where each bucket is a linked list of entries) or open addressing (where a collision triggers a search for the next available slot).
- Proper handling of collisions ensures that even with duplicate entities, the overall performance remains optimal.
3. Scalability:- Hash tables scale well with the number of entities. As more entities are added, a well-implemented hash table can resize itself to maintain performance, ensuring that operations remain O(1) on average.
- This scalability is crucial when dealing with large datasets or complex drawings in ARX.
ARX and Hash TablesIn the context of ARX (AutoCAD Runtime Extension), using a hash table to manage and delete duplicate entities is beneficial due to the following reasons:
1.Unique Identification:- Each entity can be uniquely identified using a hash value that combines various properties (such as geometry, layer, color, etc.).
- This unique identification ensures that only truly identical entities are considered duplicates.
2.Performance:- AutoCAD drawings can contain thousands or even millions of entities. Using a hash table to manage duplicates ensures that the process remains efficient and does not degrade performance.
- This efficiency is especially important in complex CAD environments where users require quick and responsive operations.
Sample Code for Removing Duplicate Entities Using a Hash Table
Here’s a corrected and complete code sample in ARX for removing duplicate entities using a hash table:
* @brief Removes duplicate entities, keeping only unique ones.
* @param objectIdArray Array of entity object IDs
* @param param Bitmask parameter used for selectively calculating the hash value:
* - 1: Use the entity's dxfName
* - 2: Use the entity's layerName
* - 4: Use the entity's colorIndex
* - 8: Use the entity's linetypeName
* - 16: Use the entity's linetypeScale
* - 32: Use the entity's lineWidth
* - 64: Use the entity's GRIP Point array (nStretchPts)
* - 128: Use the entity's bounding box (box)
* - 256: Use the entity's centroid
* - 512: Use the entity's description (entity->desc())
void XdDbUtils::RemoveDuplicateEntities(AcDbObjectIdArray& objectIdArray, int param)
std::unordered_map<size_t, AcDbObjectId> entityHashmap;
AcDbObjectIdArray remainingObjects;
// Iterate through the entity object array
for (int i = 0; i < objectIdArray.length(); ++i) {
AcDbObjectId objectId = objectIdArray[i];
AcDbEntity* pEntity = nullptr;
if (acdbOpenAcDbEntity(pEntity, objectId, AcDb::kForRead) == Acad::eOk && pEntity) {
// Calculate the hash value of the entity
size_t hash = XdDbUtils::CalculateHash(pEntity, param);
// Check if the hash value already exists in the hash table
if (entityHashmap.find(hash) == entityHashmap.end()) {
// The hash value does not exist, add to the hash table and remainingObjects array
entityHashmap[hash] = objectId;
remainingObjects.append(objectId);
// Close the entity
pEntity->close();
// Replace the original objectIdArray with the remainingObjects array
objectIdArray = remainingObjects;
ConclusionUsing a hash table to delete duplicate entities in ARX is highly efficient due to the hash table's fast lookup, insertion, and deletion operations. This efficiency is crucial for maintaining performance in complex AutoCAD environments, ensuring that even large datasets are processed quickly and accurately.
(defun c:xdtb_removeovents (/ ss len ret)
(xdrx-begin)
(if (setq ss (xdrx-ssget
(xdrx-string-multilanguage
"\n选择要处理的对象<退出>:"
"\nSelect objects to process <Exit>:"
(setq len (sslength ss))
(setq ret (xdrx-entity-removeduplicates ss 129))
(xdrx-prompt
(xdrx-string-formatex
"\n共删除了 %d 个重复的实体."
"\nA total of %d duplicate entities have been removed."
(- len ret)
(xdrx-end)
