Hey all,
looking for away to set layers on/off/freeze/thaw bij filter name.
After alot of searching, i have noluck
![sad :-(](http://www.theswamp.org/Smileys/black/sad.gif)
the next thing is, try to find the layers that are in a layer filter.
At this moment i'm stuck at the point that ik have the filter names, but no layers.
I have tried to look in to de dxf code's, i just can't find it.
The reason i need this is, to run a lot of drawings.
And i need the layers on/off by filtername.
thx for the help, John
(defun :LayerFilterList (/ :SubFilterList)
(defun :SubFilterList (dict / ent lst)
(foreach ent (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 350)) dict))
(setq lst (append lst
(cons ent (if (assoc 360 (entget ent))
(:SubFilterList (entget (cdr (assoc 360 (entget (cdr (assoc 360 (entget ent)))))))))))))
lst)
(mapcar '(lambda (x) (cdr (assoc 300 (entget x))))
(:SubFilterList (dictsearch
(vlax-vla-object->ename
(vla-getextensiondictionary
(vla-get-layers
(vla-get-activedocument
(vlax-get-acad-object)))))
"ACLYDICTIONARY"))))
(:LayerFilterList)
