Author Topic: Equivalent to a dotted pair in VBA  (Read 4548 times)
Amsterdammed
« on: July 17, 2005, 03:48:25 PM »
It is funny how you can miss thinks like a dotted pair in VBA.
The Job I got to do is simple. I have a input file with information, names and hours, they belong together. I don’t know how many pairs there are, that differs.
So I want to display them in to listboxes, the user selects the name, the hours belonging to the name appear then in a text field and can be edited by the user. This is necessary because the user can choose the name several times for input, and I want the hours he fills in counted of the original amount.
I know a little about  array, but I think the are not Public?
In lisp I would do this with a dotted pair, but how to do in VBA ?
Thanks in Advance,
Bernd
« Reply #1 on: July 18, 2005, 09:18:00 AM »
An array to keep objects together and easily manageble would eb the way to go ...
Try this:
Public Function MyFunction() As Variant
'declare variables
Dim Data As String
Dim DataFile As Integer
Dim MyArray() As Variant
Dim N As Integer
Dim SplitData As Variant
'open ourdata file
Open FileName For Input As #DataFile
'initialize our counter (not really needed but I always do)
N = 0
'loop through the file until the End of File
While Not EoF(#DataFile)
 'resize our array to include the data we are reading
 ReDim Preserve MyArray(N,1)
'read the data into our variable
 Line Input #DataFile, Data
'split it into 2 parts (I used a . because you asked about a dotted pair)
 SplitData = Split(Data,".")
'take the split pair array and put it into
'our multi dimensional array
 MyArray(N,0) = SplitData(0)
 MyArray(N,1) = SplitData(1)
'increment our counter
 N = N + 1
'loop
Wend
'close file
Close #DataFile
'return the array to the calling function
MyFunction = MyArray
End Function
Now the disclaimer .. this was written on the fly, so it may contain errors and/or omissions ... you should check it before trying to use it.
Amsterdammed
« Reply #2 on: July 18, 2005, 01:24:23 PM »
Keith,
Can an array be public ?
Bernd. :?:
« Reply #3 on: July 18, 2005, 03:05:52 PM »
yes
at the top of your module:
Public MyArray() As Variant
Amsterdammed
« Reply #4 on: July 19, 2005, 07:05:57 AM »
Keith,
If i place the Public MyArray i get a MsgBox with the contens
Constants, fixed-length strings, arrays, user-defined types and Declare statements not allowed as members of object modules
Any Idea how to sail around this?
« Reply #5 on: July 19, 2005, 08:22:35 AM »
Move it out of the form code. you should put the declare in a regular module.
Amsterdammed
« Reply #6 on: July 19, 2005, 09:33:40 AM »
:D
It is always so easy, if you know it.
Thanks a lot , early Bird
Bernd
