I am using a c# plugin to do some changes to a file and then prepare a properly scaled viewport for plotting a png, then in a batch script I'm applying this to thousands of files with accoreconsole.exe where I load the file, apply the plugin, and plot.
On some files the linetypescaling isn't coming out as expected and I can't find the reason for this. LTSCALE and PSLTSCALE are the same on all files, what other settings should I be looking at?
edit: forgot to add, the linetype scaling is different after plotting from accoreconsole than it is after running the plugin in editor, that's another head scratcher for me, is it connected to the first issue?
