Author Topic: 3d polyline splitting  (Read 468 times)
mariolino0099
« on: April 18, 2024, 09:13:29 AM »
Hi, I have a problem with this code, it divides only the first unit of each segment and not all segments with distance equal or less than the assigned value.
The code should subdivide each segment of the 3dpoly with a value such that each subdivision is less than or at most equal to the assigned value. So for each segment of the 3dpoly there is a different value with which to subdivide that specific segment.
Can anyone help me ?
(defun c:poly_add_vertex (/ *error*       c_doc  sv_lst sv_vals
  mdst ss cnt    vlst   ent    elst
  obj flg sp     ep     lcnt   dst
  tdst p
  (defun *error* (msg)
    (mapcar 'setvar sv_lst sv_vals)
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))
      (princ (strcat "\nAn Error : " msg " occurred."))
  ) ;_end_*error*_defun
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
sv_lst (list 'cmdecho 'osmode)
sv_vals (mapcar 'getvar sv_lst)
  ) ;end_setq
  (mapcar 'setvar sv_lst '(0 0))
  (initget 7)
  (setq
    mdst (getreal "\nEnter Max Distance between Polyline Vertices : "
  (setq ss (ssget ":L" '((0 . "*POLYLINE"))))
    (ss
     (repeat (setq cnt (sslength ss))
       (setq elst (entget (setq ent (ssname ss (setq cnt (1- cnt))))))
       (cond ((or (= 2 (logand 2 (cdr (assoc 70 elst))))
  (= 4 (logand 4 (cdr (assoc 70 elst))))
     (t
      (setq vlst nil
    obj (vlax-ename->vla-object ent)
    flg (if (= (vlax-get obj 'objectname) "AcDbPolyline")
   T
   nil
    sp 0
    ep (vlax-curve-getendparam ent)
    vlst (cons (if flg
(reverse
   (cdr (reverse (vlax-curve-getstartpoint ent)))
       vlst
    lcnt 0.0
      ) ;end_setq
      (while (< sp ep)
(setq dst  (distance (vlax-curve-getpointatparam ent sp)
     (vlax-curve-getpointatparam ent (1+ sp))
      tdst dst
(cond ((> dst mdst)
       (while (> tdst mdst)
(setq vlst (cons
      (if flg
(reverse
  (cdr (reverse
(vlax-curve-getpointatdist
   ent
   (setq lcnt (+ lcnt (/ mdst dst)))
  ent
      vlst
       tdst (- tdst mdst)
) ;end_setq
       ) ;end_while
) ;end_cond
(setq sp   (1+ sp)
      vlst (cons
     (if flg
       (reverse
(cdr
   (reverse (vlax-curve-getpointatparam ent sp))
     vlst
      lcnt (vlax-curve-getdistatparam ent sp)
) ;end_setq
      ) ;end_while
      (cond (flg
     (setq sp 0)
     (while (< sp ep)
       (vlax-invoke obj 'setbulge sp 0.0)
       (setq sp (1+ sp))
      (vlax-put obj 'coordinates (apply 'append (reverse vlst)))
       ) ;end_cond
     ) ;end_repeat
    (t (alert "Nothing Selected"))
  ) ;end_cond
) ;end_defun
;"AcDb2dPolyline" if curved
ribarm
  • Marko Ribar, architect
Re: 3d polyline splitting
« Reply #1 on: April 19, 2024, 08:16:59 AM »
  1. (defun c:splitpolylines ( / gap ss i poly segx d r )
  2.   (initget 6)
  3.   (setq gap (cond ( (getdist "\nPick or specify gap <0.0> : ") ) (0.0)))
  4.   (prompt "\nSelect polylines on unlocked layer(s)...")
  5.   (if (setq ss (ssget "_:L" (list (cons 0 "*POLYLINE"))))
  6.     (repeat (setq i (sslength ss))
  7.       (setq poly (ssname ss (setq i (1- i))))
  8.       (vl-catch-all-apply (if command-s (function command-s) (function vl-cmdf)) (list "_.explode" poly))
  9.       (foreach seg (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex (ssget "_p"))))
  10.         (cond
  11.           ( (= (cdr (assoc 0 (setq segx (entget seg)))) "LINE")
  12.             (setq segx (subst (cons 10 (mapcar (function +) (cdr (assoc 10 segx)) (mapcar (function *) (mapcar (function /) (mapcar (function -) (cdr (assoc 11 segx)) (cdr (assoc 10 segx))) (list (setq d (distance (cdr (assoc 10 segx)) (cdr (assoc 11 segx)))) d d)) (list gap gap gap)))) (assoc 10 segx) segx))
  13.             (setq segx (subst (cons 11 (mapcar (function +) (cdr (assoc 11 segx)) (mapcar (function *) (mapcar (function /) (mapcar (function -) (cdr (assoc 10 segx)) (cdr (assoc 11 segx))) (list d d d)) (list gap gap gap)))) (assoc 11 segx) segx))
  14.             (entupd (cdr (assoc -1 (entmod segx))))
  15.           )
  16.           ( t
  17.             (setq r (cdr (assoc 40 segx)))
  18.             (setq segx (subst (cons 50 (+ (cdr (assoc 50 segx)) (/ gap r))) (assoc 50 segx) segx))
  19.             (setq segx (subst (cons 51 (- (cdr (assoc 51 segx)) (/ gap r))) (assoc 51 segx) segx))
  20.             (entupd (cdr (assoc -1 (entmod segx))))
  21.           )
  22.         )
  23.       )
  24.     )
  25.   )
  26.   (princ)
  27. )
  28.
HTH.
M.R.
« Last Edit: April 20, 2024, 08:55:10 AM by ribarm »
M.R. on Youtube
mariolino0099
« Reply #2 on: April 22, 2024, 02:21:15 AM »
Marko many thanks,
the code should do the splitting as shown in the image. Basically introduced the user length (0.7 in the example), do the splitting of each individual segment of the 3dpoly and then round to the nearest integer and use a different splitting length for each segment
thanks
DEVITG
« Reply #3 on: April 22, 2024, 03:29:13 PM »
@mariolino099
Please Upload your sample.dwg
mariolino0099
« Reply #4 on: April 23, 2024, 02:27:03 AM »
thanks..
DEVITG
« Reply #5 on: April 27, 2024, 08:01:50 AM »
@mariolino0099 , i will check .
mariolino0099
« Reply #6 on: April 30, 2024, 11:32:23 AM »
this is the result with my code, it correctly performs the subdivision calculation, but it only subdivides the first unit of length for each segment condensing all subdivisions there without making a uniform subdivision.
Thnaks
