Author Topic: Anyway to check AutodeskID with lisp  (Read 2199 times)
kruuger
« on: April 02, 2024, 11:29:59 AM »
Hello,
Is there any way to check AutodeskID for logged in user?
We can check if user is on serial or subscription with (getvar "_pkser").
But if subscription, than what login?
d2010
Re: Anyway to check AutodeskID with lisp
« Reply #1 on: April 02, 2024, 12:37:43 PM »
You can check. current username, windows7 or 8.
(Getenv "USERNAME") inside autolisp..
For better, and you must be ensure, what you need , then you check. many variabile-names
"USERDOMAIN=yuri-PC121hdd25
USERNAME=yuri
USERPROFILE=D:\Users\yuri
LOCALAPPDATA=D:\Users\yuri\AppData\Local
LOGONSERVER=\\YURI-PC121HDD25
NUMBER_OF_PROCESSORS=4
Eg.1 you (and (getenv "USERNAME")  (getenv "LOGONSERVER"))
Lonnie
« Reply #2 on: April 02, 2024, 01:52:43 PM »
in 2025 there is an
onlineusername
Displays the Autodesk account name of the user whose currently logged into this product.
If no one is currently logged in, the value returned is an empty string.
kruuger
« Reply #3 on: April 02, 2024, 05:49:23 PM »
in 2025 there is an
onlineusername
probably that's what i need but for 2024 and older :(
kruuger
« Reply #4 on: April 02, 2024, 05:51:16 PM »
USERNAME=yuri
yes, but i think none of these older variable return autodeskID.
CodeDing
« Reply #5 on: April 02, 2024, 06:28:47 PM »
in 2025 there is an
onlineusername
That System Variable has been around for a long time now. Should work in your autocad also:
  1. (getvar 'ONLINEUSERNAME)
Senior CAD Tech & AI Specialist
Need AutoLisp help?
Try my custom GPT 'AutoLISP Ace'
Lonnie
« Reply #6 on: April 02, 2024, 06:47:02 PM »
in 2025 there is an
onlineusername
beat me. I'm going from 2021 to 2025
There are 52 new variables I am going over right now.
These are the defaults
_ACTIVITYINSIGHTSPATH C:\Users\lshaw\AppData\Local\Autodesk\ActivityInsights\Common
_ACTIVITYINSIGHTSSTATE 0
_ACTIVITYINSIGHTSSUPPORT 3
_ACTIVITYINSIGHTSVIEWEDLOGGING 0
_ANNOSCALEZOOM 0
_AUTOPLACEMENT 1
_BGCOREPUBLISH 1
_BLOCKCREATEMODE 0
_BLOCKEXCLUDECOLOR 7
_BLOCKINCLUDECOLOR 3
_BLOCKSDATACOLLECTION 1
_BLOCKSYNCFOLDER "C:\Users\lshaw\AppData\Roaming\Autodesk\AutoCAD 2025\R25.0\enu\"
_BLOCKTARGETCOLOR 3
_CENTERLTYPE
_CLOUDCOLLABMODIFIEDOPTION 0
_COMMENTHIGHLIGHT 1
_COUNTCHECK 2
_COUNTCOLOR 3
_COUNTERRORCOLOR 1
_COUNTSERVICE 1
_DISPSILHBLOCKS 1
_DX12FRAMERATEUNLIMITED 0
_ENABLEDSTLOCK 0
_ENABLESYNCPDF 1
_FASTSHADEDMODE 0
_HPDRAWMODE 0
_HPPATHALIGNMENT 1
_HPPATHWIDTH 0.2500
_JIGZOOMMAX 0
_JIGZOOMMIN 0
_MACROINSIGHTSSUPPORT 1
_MACRONOTIFY 1
_MARKUPASSISTMODE 1
_MARKUPPAPERDISPLAY 1
_MARKUPPAPERTRANSPARENCY 90
_MARKUPSELECTIONMODE 1
_MTEXTEDENCODING 0
_PASTESPECMODE 0
_PLACEMENTSWITCH 1
_REVCLOUDAPPROXARCLEN 0.0000
_REVCLOUDMAXARCLENGTH 0.5000
_REVCLOUDMINARCLENGTH 0.5000
_SHOWNEWSTATE 0
_SSMDETECTMODE 1
_STYLUSFORCETHRESHOLD 2
_SYSFLOATING 0
_TRACEFADECTL 40
_TRACEOSNAP 0
_TRACEVPSUPPORT 1
_VIEWBACKSTATUS 0
_VIEWFWDSTATUS 0
_WBLOCKCREATEMODE 1
BIGAL
  • 40 + years of using Autocad
« Reply #7 on: April 02, 2024, 07:25:24 PM »
Like Kruger subscription returned a serial number using _pkser like 000-0000000. I am sure there will be somewhere in the registry an ID. Any ideas.
kruuger
« Reply #8 on: April 03, 2024, 02:23:40 AM »
in 2025 there is an
onlineusername
WOW! Really ?!
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #9 on: April 03, 2024, 03:05:06 AM »
Well, I've learnt something new today . . .
I can go to bed now :-)
Called Kerry in my other life
I live at UTC + 13.00
« Reply #10 on: April 03, 2024, 03:18:44 AM »
This is documented in the entitlement API... I think
57gmc
« Reply #11 on: April 03, 2024, 01:06:12 PM »
I was going to suggest the entitlement api, but it's documented in Help.
« Last Edit: April 05, 2024, 03:48:21 PM by 57gmc »
d2010
« Reply #12 on: April 05, 2024, 10:42:00 AM »
My trick, you must use many-variabiles (minim 7..10variabiles) , in that way,
  you customize very-power , you customize the user-name and user-autoCAdID.
You upgrade the (getvar "AutoCadID") with
   (checkallEqu (list (getvar "AutoCadID")  (getenv "USERNAME") (getvar "_PKSER")
               (getenv "LOGONSERVER")  (getvar "ONLINEUSERNAME") (getvar "ACADVER")
               (wcmatch *2025* (getvar "_BLOCKSYNCFOLDER"))
 :idea:
« Last Edit: April 05, 2024, 12:04:00 PM by JohnK »
57gmc
« Reply #13 on: April 05, 2024, 03:43:37 PM »
 :idea:
ONLINEUSERNAME returns the public profile name of the Autodesk account you use for your subscription.
« Last Edit: April 05, 2024, 04:28:12 PM by 57gmc »
kruuger
« Reply #14 on: April 08, 2024, 04:53:01 AM »
 :idea:
Yes, as CodeDing mentioned earlier. Variable works well. All good,
